looking for a high flow fuel pump to replace my fass
Old Nov 26, 2009 | 07:33 PM
coldair's Avatar
Default looking for a high flow fuel pump to replace my fass
I have lost all confidence in my fass to maintain pressure as twice it has left my truck riding home on a flatbed hauler. the fass had a 5/8" check ball instead of a 3/4" it should have had and burned up the pump. now even with the right ball it has dropped pressure to zero so it has to go. I still have a dahl 100 filter fuel line cooler, but I need a good quiet fuel pump. something that will work with my 5/8" tank fuel line and my ITP regulated return with fuel bowel delete.
what do you all recommend
Old Nov 26, 2009 | 08:42 PM
12vcummins96's Avatar
have you thought about the air dog i am happy with mine
Old Nov 27, 2009 | 03:10 AM
joebob3093's Avatar
Moderator
what about a walbro or an fuelab?
Old Nov 27, 2009 | 12:52 PM
CSIPSD's Avatar
Air dog has a new high pressure pump they just came out with... Seems to be getting great reviews...
I am getting by fine with a stock pump pushing 250cc hybrids...
Old Nov 28, 2009 | 06:39 PM
coldair's Avatar
a couple of things I would like to accomplish is to make it realable and quiet. I have 2 layers of sound deadening and you can still hear that pump above my turbo and it sounds like its coming apart. I guess the air dog is noisy too
Old Nov 28, 2009 | 06:41 PM
my air dog is very quiet i cant hear it inside the truck with the truck running and the windows down
Old Nov 28, 2009 | 06:50 PM
coldair's Avatar
put are you using it on a dodge where the pressure is much lower?
the fass is normally mounted on the frame rail near the rear spring hanger on my X I had to mount it right behind the transmission cross member.
I am thinking it might be better to use the fass for low pressure to feed a high pressure pump
Old Nov 28, 2009 | 07:09 PM
captain_stabbin's Avatar
that bs, i think fass ought to back up there product!
Old Nov 28, 2009 | 07:27 PM
The Guys at FASS will take care of ya. Give them a call on Monday.
Old Nov 28, 2009 | 10:15 PM
CSIPSD's Avatar
Fass really suck when it comes to a higher pressure pump. Everyone I know that runs one eats one every few months...
I would run a low pressure airdog as a pickup pump and a stock fuel pump as your HP pump. Easy, symple and works.
