pros and cons of getrags and nv4500s?
Old Nov 23, 2009 | 09:09 AM
86k5's Avatar
Default pros and cons of getrags and nv4500s?
whats the differences
Old Nov 23, 2009 | 09:55 AM
NadirPoint's Avatar
Getrag = good. NV = bad.
Old Nov 23, 2009 | 11:37 AM
94Matt's Avatar
Wow, I have always heard that the other way around.
Getrag = bad, but can be ok if you run extra oil. NV = good with exception of 5th gear nut occasionally on early 4500's.
Old Nov 23, 2009 | 12:52 PM
86k5's Avatar
well these dont help do the getrags have the 5th gear problem
Old Nov 23, 2009 | 01:16 PM
94Matt's Avatar
My understanding is that the getrag can have problems with lubrication and weak input shafts. They do not have the 5th gear nut problem. NV4500's have a problem with the 5th gear nut and when you go real big on power, people put in even bigger, fully splined main shafts which takes care of the nut problem.
I think either one is a tough transmission, but the best would be a NV5600 (six speed) which really has no issues.
Old Nov 23, 2009 | 01:44 PM
NadirPoint's Avatar
Oil for an NV4500 costs about $100 per fill.
Old Nov 27, 2009 | 09:46 AM
smokincummins92's Avatar
Ok i had always heard that the nv4500 was the way to go to. So you say that all the getrag needs is about an extra quart of oil? How much power can one take without changing the shafts?
