Need help bad
Old Nov 20, 2009 | 10:13 PM
NCFPD's Avatar
Default Need help bad
Ok i just put in my new vp bec. the old one died. i have every thing hooked up chacked and doudle checked the lines have been blead to ibut i cant get no fire at all no puts nothing i do get a little haze outta the stack for a sec. after trying to start it and it smells kina like burnt paper what am i doing wrong i eed help getting my truck running
Old Nov 20, 2009 | 10:41 PM
wildbill's Avatar
Did fuel dribble or somewhat spray our of the injector lines?? Might have to loosen the feed line to the VP and crank it over until you got a good stream of fuel. Then loosen #3 injector line until you get some fuel, then do the same with #5. Should start then. BUT do NOT use either.
Old Nov 20, 2009 | 11:21 PM
NCFPD's Avatar
yea i have fuel coming from the lines at injector hook up it comes out a little and i have loosened the line from the filter to the vp and made a mess so i know i have fuel there
Old Nov 21, 2009 | 02:17 PM
wildbill's Avatar
Going to close this thread due to an active thread in the Dodge section.
|WYG|SS
Jul 26, 2015 11:18 AM
|WYG|SS
Jul 4, 2015 08:31 AM
Cumminsmoney
Mar 20, 2015 02:33 AM
Feb 5, 2015 12:10 AM
12vbomber
Nov 11, 2014 10:58 AM
