94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
stage 2's
Old Nov 17, 2009 | 07:25 PM
smokin stroker's Avatar
Default stage 2's
will my stock garret hold up to stage2 injectors and will my stock fule/oil systems support them.
Old Nov 17, 2009 | 07:43 PM
joebob3093's Avatar
Moderator
the turbo will hold if you dont go over 25psi. it will be really smokie and probably get pretty hot pretty quick. oil and fuel will suport it but im not sure how well. you will need a fuel and hpop pressure guageto find out.
Old Nov 18, 2009 | 04:55 AM
CSIPSD's Avatar
Stage 2's with mild nozzles will be fine. Whos stage 2 injectors and what size are they?
With your 1.15 exhaust housing it will be perfect! 25 is a little over safe IMHO, with the slower shaft speeds because of the 1.15 housing you would be fine in the 30-33 range...
If your fuel pump is good you will be fine, but I would get a electric fuel pressure gauge to be safe, keep it around 65-70 at idle and no less then 30 at WOT.
HPO pressures... you will just have to watch, if you have to you can get a Super Duty (17*)HPOP and swap that it...
Old Nov 18, 2009 | 06:22 PM
ok thanks for the info. what brand would you suggest
Old Nov 18, 2009 | 07:13 PM
joebob3093's Avatar
Moderator
swamps or cass injectors.
Old Jan 5, 2010 | 07:44 PM
powerstroker52's Avatar
i would get a HPOP out of a superduty like csipsd had said, i had stage ones in mine and it threw the check engine light when getting on it for any period of time because the injector pressure was getting low and strokers use oil to pop the injector so basically the truck wasnt pushing enough oil threw the system with the 15* pump.
truckerchuck76
Aug 14, 2015 10:46 AM
Diesel Addict
Price Quote - Request A Price
Jul 23, 2015 02:28 AM
Apr 29, 2015 08:20 AM
DPRacing805
For Sale
Nov 15, 2014 12:47 AM
Zakkb787
LB7 Performance
Sep 27, 2014 08:47 PM
