Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Jet fuel
Old Nov 15, 2009 | 04:36 AM
Deezel Stink3r's Avatar
Default Jet fuel
Has anyone used JP 8 (Nato number F34) fuel?
Being deployed they used Jet Fuel instead Diesel. The trucks (equipped with a turbo) started to smoke black immedeatley. They called it Diesel de luxe
black Smoke = unburned fuel = higher BTU included in JP8
If I turn up the boost - it should burn clean....
Old Nov 15, 2009 | 04:42 AM
bryson's Avatar
Let us know how it works out.
Old Nov 15, 2009 | 06:09 AM
ChinookFE's Avatar
I've run JP8 in my truck(Diesel was 5/gal and we had gallons of it just sitting around)....I would put about 5 gal. of JP8 in a tank w/ reg diesel fuel w/ no issues...Same mileage, no extra smoke that I noticed
Old Nov 15, 2009 | 06:26 AM
And pure JP8?
Old Nov 15, 2009 | 06:38 AM
nate379's Avatar
You will loose fuel mileage, but if it's free I guess that doesn't matter.
AFAIK It's pretty much the same as #1 diesel fuel.. from Exxon:
Why shouldn’t I just use Diesel Fuel No. 1?
While Diesel Fuel No. 1 has an advantage in low temperature operability, there are some disadvantages, as well. The energy content of Diesel Fuel No. 1 is about 95% that of Diesel Fuel No. 2 and will provide a correspondingly lower fuel economy. Diesel Fuel No. 1 is also lower in viscosity and provides less lubrication for the fuel pump and fuel distributor.
Old Nov 15, 2009 | 07:37 AM
I don't have a Common Rail- so lubricity isn't that prob. I just wonder about the BTU of Jet Propellant.
Old Nov 15, 2009 | 07:40 AM
Johnny Z's Avatar
Old Nov 15, 2009 | 04:20 PM
ChinookFE's Avatar
just regular JP8...
Old Nov 16, 2009 | 07:34 AM
Preacher's Avatar
I've seen guys run JP5, I wouldn't suggest running a complete tank of it. The most I'd go would be 50/50. Also don't get caught, because it will be Fraud, Waste and Abuse, and you can be NJPed for it.
Old Nov 16, 2009 | 11:22 AM
K50's Avatar
K50
IIRC, the lubricity of jet fuel is much lower!!
I heard it's a bad idea to use it because it's more of a solvent and will not lubricate like diesel does, thus leading to faster wear.
