truck shuts off on hot unlock
Old Nov 13, 2009 | 10:11 AM
dirt diggler's Avatar
Default truck shuts off on hot unlock
when im running my truck hard an let off it dies its a real pain to get started. When it finally starts there is no miss or eny thing. it has a fass pump. but should i get my fuel press checked. Iv also been told whith the hot unlock an 150 inj if you dont let off real slow it will do this? im goin to be sled pullin an dont want to be pulled of the track at the end of the run eny help would be great thanks
Old Nov 14, 2009 | 02:29 AM
wildbill's Avatar
Does it only do it with the Edge turned on??
Old Nov 14, 2009 | 03:46 AM
yea it only does it whith it turnd on. had my fuel press and codes checked tonight every thing looked good. Its got me puzzeld thanks
Old Nov 14, 2009 | 04:51 AM
Jazz's Avatar
Can you stay into it full throttle and still run? It's just when you let of the throttle. Are you just on the edge of running the vp dry? I wouldn't think so I'm thinkin it must be with the edge. Not sure what or why. Anyone else have any ideas?
Old Nov 14, 2009 | 06:16 AM
wildbill's Avatar
Sounds like it could also be a bad box.
Old Nov 17, 2009 | 09:16 PM
wildbill's Avatar
Updates??
Old Nov 18, 2009 | 05:44 AM
not eny updates yet
Old Nov 18, 2009 | 05:55 AM
wildbill's Avatar
Boils down to this, new box or send yours in to be checked.
Old Nov 18, 2009 | 07:47 AM
12vcummins96's Avatar
when running your truck hard like that especially in a 24 valve with that setting it cranks the timming up real high so when you let off quickly it cant compansate for it and it dies get that box checked or put it in another setting and see if it does it thier
Old Nov 18, 2009 | 08:07 AM
that makes good sence to me thanks ill try another setting thanks brad
