Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Lubro Moly Diesel Purge
Old Nov 11, 2009 | 09:15 AM
Marine's Avatar
Default Lubro Moly Diesel Purge
Hey all,
I have a friend with a Nissan of some sort. Right hand drive, diesel. He was told to use this lubro moly Diesel purge to clean the injectors. You by pass the filter and have the injection pump suck this stuff in, recirculate the overflow back into the bottle, so all that is entering the injection pump is this diesel purge.
Ingredients are: 65% Diesel Fuel, approx. 25% Ethylhexyl nitrate, approx. 8% Petroleum Distilate, and approx. 1% 1,2,4-Trimethylbenzene.
We did it last night and he says it made a big difference. His symptoms seemed like the glow plugs were not working; low power and white smoke while under load.
Has anyone here tried this?
Thanks!
Here is the link: Diesel Purge
Old Nov 12, 2009 | 12:10 PM
Marine's Avatar
Anybody?
Old Nov 15, 2009 | 04:48 AM
Deezel Stink3r's Avatar
Yes, that stuff is sold under the same brand and name in Germany in pro Retailer shops.
The use you described is for heavy symptoms. Usually you pour it into the fuel tank. Your friend has used cheap diesel or bad diesel a long time. He should change the fuel station if possible. Does he use Bio Diesel and regular Diesel mixed?? That happens also if you mix fuels.
That Petroleum Distilate, also known as Naphta is the solving agent that cleans the injector.
1.SGT GAF
Old Nov 16, 2009 | 09:37 AM
Marine's Avatar
It was a used Safari that he had. Says it was a huge difference in performance.
Old Nov 16, 2009 | 10:09 AM
Injectors and VP's have very tight tolerances. Any dirt buildup will cause less performance or failure.
I bring my injectors once a year to have them checked for release pressure and beam pattern. I don't like to have a dripping injector.
Old Nov 20, 2009 | 10:30 AM
CROWN14's Avatar
Anyone ever used this on a Cummins? I have a friend with a whole case of this stuff in his shop...
Old Nov 20, 2009 | 11:00 AM
Marine's Avatar
What kind of shop is it? He hasn't used it in a Cummins I take it?
Old Nov 20, 2009 | 11:27 AM
CROWN14's Avatar
Its a euro repair shop, he used to have a powerstroke truck but bought a whole case to sell to mercedes diesel customers and never sold any of it I dont think.
Old Nov 20, 2009 | 01:18 PM
Marine's Avatar
You should see what you can pick it up for.
It smells awfully like PowerService in the white bottle.
Old Dec 9, 2009 | 12:16 PM
I would take it. It's Pro stuff and not sold to the common public. You can get it only in shops for retailers in Germany.
I assume it's not containing the green eco frog...
