twin help
Old Nov 9, 2009 | 01:20 PM
jl99cummins's Avatar
Default twin help
guys just wondering if anyone has run a twin setup with a set of 150's and edge comp. Looking for lower egts towing also what would go with the stock hx 35 thanks
Old Nov 10, 2009 | 03:14 AM
mxtuner1's Avatar
Of couse we need to know how much boost you want- stock shouldn't go over 40 lbs without head studs- h11 studs can be put in and will allow 80!!!! lbs. The secret(?) to low egt's is get rid of restrictions - your hx35 is the most restrictive thing on you engine - but you can externally wastegate in front of it for twins to lower egt's. Good luck my friend.
Old Nov 10, 2009 | 10:23 AM
nbaca's Avatar
with only 150s and a hx35 over a ht3b you can use a external gate but it is not needed. cut the divider out of your hx exhaust housing and port the wastegate. you will love the twins when towing. i towed a 8k 5er like nothing with cool egts.
11B/11C
5.9L CR Performance
Jul 31, 2016 04:36 PM
heavyarms
13
Mar 20, 2016 03:24 PM
Blair@BD
BD-Power
Jul 17, 2015 12:44 PM
LadyyD
Chevy/GMC Duramax 2011 LML
10
Jun 1, 2015 05:30 PM
offroad00
24
Oct 23, 2014 03:28 PM
