Do diesels have a stochiometric air/fuel ratio??
Old Nov 6, 2009 | 09:57 PM
MikeyM's Avatar
Default Do diesels have a stochiometric air/fuel ratio??
I mean is there a "perfect" A/F ratio for diesels like their is for gas? Gas is 14.7:1 so I was wondering if there is a similar deal for diesels, us having pressurized intakes and all. Is there a metric that tells/says/shows at what point a diesel is at it's most efficient, meaning - making the most power with the least fuel and EGTs staying in check??
Mikey
Old Nov 6, 2009 | 10:03 PM
stkdram55's Avatar
I dont think so, im not sure but the 14.7 you talk about is the atmospheric presure at sea level...so im pretty sure the turbos aka forced air induction takes that all out of the equation...
Old Nov 6, 2009 | 10:19 PM
sstockton's Avatar
14.7 psi is atmospheric 14.7:1 is the ideal stochiometric ratio for gasoline. Meaning 14.7 times the mass of air to the mass of gasoline. Anything lower than 14.7:1 is a rich mixture, and anything greater is a lean mixture.
In all my searching, I have never found an ideal stochiometric ratio for diesels. I'm also not sure how you will measure it, because most gauges measure the air/fuel mixture and these are direct injection.
Sean
Old Nov 7, 2009 | 12:17 AM
12vcummins96's Avatar
there isnt an o2 sensor on a diesel
Old Nov 7, 2009 | 01:36 AM
stkdram55's Avatar
There is on the new ones
Old Nov 7, 2009 | 02:11 AM
tower_ofpower's Avatar
i thought it was more along the lines of 13.6 for gassers being "ideal" the fuel ratio does exist... talked about it BREIFLY in school but really doesn't have much relevance in a diesel... from what i've learned diesels typically run very lean at idle being that they have X ammount of air which is X number of times greater than the fuel being injected. and well as for richness... the sky is really the limit, no spark plug to flood out. then again you can hurt performance by using too much fuel with out enough air such as bogging down on a no boost take off at WOT
Old Nov 7, 2009 | 03:39 AM
2500HeavyDuty's Avatar
Well we all shoud know if it is past the ideal stochiometric ratio it will just go as unburned fuel and smoke, but smoke can be fixed to with the correct timing
gzmak7
8
Apr 7, 2017 03:17 PM
Nov 26, 2014 08:10 AM
Oct 4, 2014 10:10 AM
