air dog quits....turn off key and back on it will come back on?...
Old Nov 1, 2009 | 08:08 PM
veggyoilkid's Avatar
Default air dog quits....turn off key and back on it will come back on?...
I have several times had my motor die on me while idling. Each time I can hear the air dog pump is not running. It has always happened while idling and in park. It always will start again [ both the pump and the motor ] sometimes the pump does not come on when I turn on the ignition right away. If I turn the key off and on it eventually runs and then I can start the truck and it runs as normal.
Anyone familiar with this?... I changed from a 2 micron filter to a 10 a couple days ago and it quit on me again today....
any suggestions?...
Old Nov 1, 2009 | 08:12 PM
Jet A Fuel's Avatar
Air? got a fuel pressure gauge?
Old Nov 1, 2009 | 08:15 PM
2500HeavyDuty's Avatar
check the fuses, and make sure it has good wiring. the AD does have a lifetime warrenty
Old Nov 1, 2009 | 09:04 PM
04cumminsram's Avatar
try moving your power line to airdog to a keyed on source, this isnt the first time ive heard of a airdog quitting while the truck is running !
Old Nov 2, 2009 | 05:18 AM
last night I pulled off the water separator and checked it out...seems fine
also took the cover off the pump and checked the gear rotor...seems fine too
I plan to move wiring from battery to another source and see if anything changes...
Any other suggestions?...
Oh yeah, made me think I need to carry a spare fuse, if that thing should blow I'm stranded
Old Nov 4, 2009 | 07:32 PM
ran a new power supply from the battery, omitting ECM, via a toggle switch in the cab....It did quit once on me while driving ): weird
has been fine since. And I'm beginning to suspect relay could be the problem. not sure yet
Old Nov 4, 2009 | 07:35 PM
Buck08's Avatar
Sounds like the relay. Double check for bare wires that might trip the relay.
Old Nov 8, 2009 | 09:37 PM
Truck has been running fine, don't know for sure why....
It did quit once after I moves the supply wire to a new source other then ECM
That is what makes no sense. The only issue remains is the air dog motor makes a sort've slight rumbling noise off and on. Not constant, just comes and goes irregularly. I can only guess the brushes or a bearring could be going....
Old Nov 9, 2009 | 12:29 AM
You should have a FP guage....
Old Nov 16, 2009 | 05:00 PM
steved's Avatar
REPLACE THE RELAY!!! Probably cost you $4 from RadioShack!
