94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Shimming A FPR? How?
Old Nov 1, 2009 | 07:23 PM
Krokus_96F350's Avatar
Default Shimming A FPR? How?
How do you shim the fuel pressure regulator? What do the shims look like and where you you purchase them?
Thanks, Krokus
Old Nov 1, 2009 | 07:32 PM
PSD's Avatar
PSD
The "shim" is actually a BB...shot out of a BB gun. You shim the spring in the FPR to put out 60-65 psi of fuel pressure. If i am correct..
Old Nov 1, 2009 | 07:38 PM
Thanks. Sounds simple enough. I'll give it a try next oil change.
Old Nov 1, 2009 | 07:39 PM
Whit's Avatar
Site Mascot
Shimming the fitting with a 3/16 spacer behind the spring in the fuel regulator. This is located on the right hand side of the fuel filter. You will see a 3/4 brass nut there. The spring is inside there. Shimming will raise the fuel pressure and often give you a worthwhile increase in power and no one that I can recall has reported higher fuel consumption.
Old Nov 3, 2009 | 05:50 PM
Default Re:
Is this a mod someone would do with stock injectors and 250,000 miles on the engine? Except for a new downpipe and an air intake this thing is bone stock. Being a 5 Speed the truck is very slow off the line and doesn't come alive until 3rd gear. I'm looking for a little more poop!
Old Jan 17, 2010 | 03:38 AM
g2shuck's Avatar
i love this mod its easy to do
Old Jan 21, 2010 | 04:28 PM
dieseldan73's Avatar
i did this and i didnt notice any power increase but the truck starts better
Old Mar 10, 2010 | 09:22 PM
JTProuhet's Avatar
im looking for the same answer.. Anyone?
Old Mar 10, 2010 | 11:02 PM
CSIPSD's Avatar
You will not see any HP gain with shimming the FPR, just a bit easier starting and a little smoother idle.
Old Mar 12, 2010 | 10:38 AM
cummins bronco's Avatar
i did it on my old powerstroke and didn't notice any difference at all.
it is a quick and easy mod tho so give it a try and see what happens.
