Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
water meth injection
Old Nov 1, 2009 | 05:23 PM
blacksmoke09's Avatar
Default water meth injection
hey im just trying to find out all i can about water meth injection. i get the simplest idea of it. water cools down the cylinder while burning the hydrogen as well. i just wanna know more about it if anyone has info id appreciate it
Old Nov 3, 2009 | 12:52 AM
12vcummins96's Avatar
and the meth acts as a catalyst to aid in the full burn of the fuel in result more power depending on what u use it for
it is safe to use but if running just water dontuse tap water use distilled also -20 windshield washer fluid can be used as well as heet and water depending on what percentage you want to run i run 51/49 so hope this helps you
Last edited by 12vcummins96; Nov 3, 2009 at 12:52 AM. Reason: Automerged Doublepost
Old Nov 5, 2009 | 06:41 AM
millco's Avatar
Is it for everyday use? What are the benefits for everyday use? I think it would be great for pulling or racing; but would it be worth the cost and trouble running empty?
Old Nov 5, 2009 | 09:25 AM
no it has an arm switch so run it when u want i use mine when drag racing
Old Nov 6, 2009 | 09:11 PM
mxtuner1's Avatar
Remember the methanol adds oxygen- and that's what our trucks say yumyum! to especially when we add more fuel. It would help mileage if you ran it all the time - make your own much cheaper look at 55 gallon drums of methanol - around here it is 137 dollars delivered and mix it around 50/50 purified water.
Old Nov 7, 2009 | 03:29 AM
millco's Avatar
Sounds good! How much would it help running all the time on a road trip? How much would it help around town? (I mean how much of a mileage improvement I guess . . . )
Does a guy just buy the $1,200 mileage system or is there a good / better way?
mxtuner1 I noticed your propane in your sig. I might have to get some info on that from you on that! That is another 'bomb' I want to investigate and probably install someday. If there was a way to 'diy' water/meth inject . . . (And it was worth it) . . . I might have to work on my next install!
Old Nov 10, 2009 | 02:47 AM
mxtuner1's Avatar
Default propane and methanol
Dear Millco - PM me if you want info on either propane or methanol. Sincerely, JIM and by the way I'm not in this for the money!
Cougdiesel
Feb 2, 2016 10:17 AM
Aug 27, 2015 04:00 PM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
yams
Dec 7, 2014 12:51 PM
