6.5td no power
Old Oct 31, 2009 | 12:53 PM
benadkins's Avatar
Default 6.5td no power
my 98 6.5 td dually dont feel like it has any power. i pull a 22 ft enclosed trailer with a 3500 pound car in it and my buddy pulls w a half ton 350 gas motor and i cant keep up. is this normal or is it possibl the turbo isnt working??? thanks for any help!!!
also i can hear the turbo whistling but cant feel it. it has 185000 on it!!!!
Old Nov 1, 2009 | 01:39 AM
Pyro690's Avatar
Is it blowing any smoke?
Old Nov 1, 2009 | 05:28 PM
Woody35's Avatar
has it been getting worse
Old Nov 1, 2009 | 09:03 PM
benadkins's Avatar
it seems to be gettin worse. and no it dont blow any smoke at all. the turbo keeps gettin louder also.!!!!
Old Nov 1, 2009 | 09:20 PM
wildbill's Avatar
New air filter recently?? Also, hows the condition of the hose running from the air box to the turbo?? Could be sucking shut on you, I've seen it happen.
Old Nov 1, 2009 | 10:09 PM
Woody35's Avatar
take the air filter off and check the turbo for any play
Old Nov 2, 2009 | 11:27 AM
benadkins's Avatar
yeah i change the air filter in it pretty regularly. the hoses seem to be in pretty good shape.but ya will check and see if it colapses and also will check out the turbo for play. thanks for the help
also if it sits and idles for 15 or 20 min and i take off in it it cuts in and out. its got so bad once that it quit on me. but started back up just after a few seconds. could this be related??
Old Nov 2, 2009 | 09:25 PM
Woody35's Avatar
how many miles on those injectors. try cleaning the grounds. these engines act wierd when they dont have clean eletrical connections
Old Nov 3, 2009 | 11:56 AM
benadkins's Avatar
ok. will check. as far as i no the injectors havent been messed with. iv only had the truck about a yr and a half. had 160000 when i got it. thanks for the help!!!!!!!!!
Old Nov 3, 2009 | 12:54 PM
Woody35's Avatar
injectors are rated at 100k miles but ive seen people get them to run 250k miles and so on. but if they break while the engine is running your screwed. but after 100k that start to have uneven spray pattern and cause your engine to have poor performance and crappy fuel mileage
