injecter pump not pumping
Old Oct 31, 2009 | 07:09 AM
blnt's Avatar
Default injecter pump not pumping
98 chevy 6.5 had a hard start problem and ran rough till it warmed up, the problem just kept getting worse till it just stalled, while running rough took it to the dealership they had me change the lift pump,and fuel shut off. Since then had the fuel injecter pump tested twice, changed the ignition,oil sending unit, had it hooked to another computer and showed no faults, as of now have fuel to the pump but not comming out
Old Oct 31, 2009 | 08:17 AM
Whit's Avatar
Site Mascot
you need to get the air outa the system and get the pump primed with fuel
Old Oct 31, 2009 | 08:37 AM
blnt's Avatar
and how would i do that? Bleed the system up to the fuel shut off , the lift pump got good pressure to there
Old Oct 31, 2009 | 08:39 AM
Whit's Avatar
Site Mascot
I would crack the injector lines where they go into the head
Old Oct 31, 2009 | 08:40 AM
blnt's Avatar
took the lines off right at the back of the pump, no fuel
Old Oct 31, 2009 | 08:42 AM
Whit's Avatar
Site Mascot
OK.......I guess start at the discharge of the lift pump and move forward from there till you have all the air out
Old Oct 31, 2009 | 08:46 AM
blnt's Avatar
bleed it at the filter, then at the two points it goes into the pump, cracked the fuel shut off valve, beilieve I got all the air out as far as I can
Old Oct 31, 2009 | 08:57 AM
Whit's Avatar
Site Mascot
so yer primed right up to the inlet of the injection pump then??
if this is the case I say get the lift pump running and then turn the motor over so the injection pump has opertunity to pick up the fuel....... once yer internal pump gets a prime on the fuel it should start delivery to the injectors.................just make sure you have loose lines at the injectors or the discharge of the IP when you do this
Old Oct 31, 2009 | 10:43 AM
blnt's Avatar
i'll give it a try and keep you posted, thanks
Old Nov 4, 2009 | 05:58 AM
wildbill's Avatar
Please update.
