dt466 conversion
Old Oct 29, 2009 | 10:59 PM
fordbinder's Avatar
Default dt466 conversion
I recently purchased a dt466 1985 model. It has a inline bosh pump. I want to put it in a 1 ton ford pickup 4x4. what is the best years to do this in the trucks. starting at 1973 Which would be easy. also what transmission would u use i dont care if its auto or man. I know i will have to use a divoresd transfer case. I will be putting atleast a 3lm turbo on it I want to make her run hard. i have been thinking about a 1978 4 door 4x4 shortbed having a hard time finding one though.
Old Oct 30, 2009 | 12:03 AM
dieseldocter16's Avatar
I dont know about the ford's but a buddy put a dt466 in a late 70's chevy crew cab and all he did was install a dog house from a chevy medium duty for more room in the engine bay. I'm pretty sure the 5 speed he has behind it is an NV4500. The swap looks factory.
Old Oct 31, 2009 | 05:31 AM
fordbinder's Avatar
How good did it run with the dt466? Did it have any get up and go? I was also wondering about gear ratio. I think maybe 3.55 gears might be better but I don't know. I would like to keep rpms low on interstate driving.
Old Nov 1, 2009 | 12:05 PM
nevrenufhp's Avatar
I almost did that swap into a super duty. For gears, you need some freeway flyers, 3.55 at the steepest if you dont have overdrive. Trans, I was going to use an Allison AT545 with mine, mainly due to the size and quicker shifts than the bigger ones. Suncoast makes a better converter for them to take away the rubbe band feel. The 545 is a non-lockup, non-overdrive auto, but does have 4 nicely spaced / progressive gears. For a manual, you should be able to fit an RT or RTO610, but that's more fab work with the clutch. If you're gonna up the power too much, you better have some good axles & shafts.
Fitment.... newer is better. There's a 466 swap being done to a 74 krew kab, and the back 2 cyls are in the cab. The 99 that I was gonna do, I was only needing to go into the cab about 3-4".
With that governer, there's no 3k gov spring kit. You can make your own. Take out the smallest spring in the gov spring pack. Make/ grind down 2 washers that fits the diameter of the spring and still fits in the stud. Make sure it's around 1.55mm thick for best results. Put a washer in each set of springs, and tighten to 2 -4 clicks past the factory setting(measure the original stud protrusion). You should hit at least 3200 like that. Besides that, it takes fuel and timing with your turbo. Those 3LM's arent that big are they?
Old Nov 1, 2009 | 09:04 PM
fordbinder's Avatar
My friends have plenty of upgrades from pulling tractors. How much do I exspect to pay for transmission
Old Nov 1, 2009 | 09:18 PM
nevrenufhp's Avatar
Tractor pullin sources are the best you can get for a 466!
The AT545's generally go for around $500, and around 1800-2000 for a rebuilt one. The RT610, prices I've seen are from 1400 to 2500.
Old Nov 2, 2009 | 02:56 PM
fordbinder's Avatar
ouch thats hurts the pocket book.
My friends all run pro stock classes in tractor pulling. They said they have some extra injecters. They told me to send the pump off and get 13mm plungers They told me i can turn it up to around 600 to 700 horse with no problem if i dont pull anything to heavy i would have to run gauges
are u saying the 99 and up superduty have more room? If so i should go buy a salvage truck from junk yard I can pick them up pretty cheap
Old Nov 3, 2009 | 08:28 AM
nevrenufhp's Avatar
They are about an inch more room in length than the previous generation. I found mine on craigslist, check there first.
Old Nov 16, 2009 | 11:51 PM
fordbinder's Avatar
Still no luck yet on finding pickup
Old Nov 25, 2009 | 01:58 PM
fordbinder's Avatar
I thought i had a ppump but i scraped the grease away an i have mwpump this sucks. I can still get about 380 to 450 hp it will be enough the torque will be pretty good well over 1000
