Hard Shifting 48re
Old Oct 27, 2009 | 12:55 PM
1guntoofew's Avatar
Default Hard Shifting 48re
i'm having rear end busting shifts on my 04 2500 cummins powered 48re from 3 to 4 (up shift only)and when tq con. locks up when pulling heavy load (14,000 lb backhoe). i bought truck new and it just started this. has 88k miles.
Old Oct 27, 2009 | 01:24 PM
Baxy's Avatar
sounds like the TV valve is stuck I can't remember which year has the TV cable or TV actuator either way a cable can bind up as well the actuators are known to bind up as well
Old Oct 28, 2009 | 01:12 AM
Diesel Nut's Avatar
So is it 3-4 or when the converter locks? Or both?
TV cables continued until 05, when the changed to the TV motor set up. Of all your other shifts are fine then I don't expect the TV cable to be the issue.
Old Oct 28, 2009 | 06:43 AM
1guntoofew's Avatar
it's both 3 4 & tq lock up & only under very heavy load. doesn't do it pulling my 25' camper only when pulling my gooseneck loaded in excess of 10K. i have a soft shift issue from 1 to 2 but i think thats a band issue -it wouln't adjust. i've got the tranny out now but i haven't torn into it yet.
Old Oct 28, 2009 | 09:12 PM
Baxy's Avatar
keep this thread posted I'll be interested to hear the problem
your right I miss read the problem TV would affect all shifts
do you have any accessories such as BD pressure lock or a torque locker of any kind?
Old Oct 28, 2009 | 09:50 PM
1guntoofew's Avatar
tranny is bone cold stock. running diablo sport power puck, turbo pressure turned up with boost elbo, and full 4" inch exhaust from turbo back
Old Oct 29, 2009 | 09:26 AM
Diesel Nut's Avatar
Have you got a lift and/or bigger tires or anything like that?
Old Oct 29, 2009 | 06:37 PM
1guntoofew's Avatar
no lift & factory size tires. truck is all stock except for the power puck, turbo boost, & exhaust.
Old Oct 29, 2009 | 06:47 PM
Jet A Fuel's Avatar
sounds like an accumulator piston siezed
Old Nov 1, 2009 | 07:13 AM
wildbill's Avatar
Updates??
