ball joint replacement
Old Oct 27, 2009 | 10:21 AM
dieseldocter16's Avatar
Default ball joint replacement
I took my truck for state inspection yesterday and all 4 ball joints are bad. (which i kinda figured ) Anybody have any advice or tips for replaceing them on an 01 Ram 2500 4x4?
Old Oct 27, 2009 | 11:30 AM
Whit's Avatar
Site Mascot
good stuff in here dude
https://www.dieselbombers.com/24-val...ll-joints.html
Old Oct 29, 2009 | 06:08 AM
TexasDiesels's Avatar
hey im going to replace my ball joints on my 1997 f250 7.3 powerstroke whas your steering wheel loose? where youre front tires spread apart? because mine is just asking
Old Oct 29, 2009 | 06:51 AM
The steering is loose. When they had the truck on the lift and pryed up on the tire you could see the upper and lower joints moving.
Old Oct 29, 2009 | 06:59 AM
Whit's Avatar
Site Mascot
WOW.....thats bad
I just checked mine here a few months ago....................019 drivers side and .021 passenger ....................! have 150k on the truck
Old Oct 29, 2009 | 05:27 PM
im mad me and my dad and uncle were changing the ball joins on my truck and they didnt fit !!
i need a ride for school tomorrow
Old Oct 30, 2009 | 12:16 AM
That sucks. I'm still shopin around for joints. The damn local automotive wants $500.00 for 4 Moog's, oil seals, dust shields, and u-joints for the axle shafts.
Old Oct 30, 2009 | 12:49 AM
Benjamin's Avatar
Bombardier
you don't want to cheap out on a ball joint,
short history on my truck
stock balljoints lasted to 120K and you could wobble them all around in the cup, they almost came loose, replaced them with TRW (Advance Auto brand) got alignment done, 3 months later doing brakes and find the balljoints are wobbly and clunking all around, remove them get them warrantied out, 3 months later i am chasing a clunk in the front end, replace all control arm bushings, sway bar end links, shocks, find balljoints again bad, take them back and get refund, go and spend almost 3X as much on Moogs, replace them, all is good for a year go to lower the truck and the lower ball joints are bad, take them back and get them replaced..... the Dodge front end geometry is wacked out IMHO and the balljoints suffer because of this, this was on a 1996 2wd IFS 1ton.
Old Oct 30, 2009 | 05:19 PM
That sucks my uncles is charging us 200$ for installing them.
Old Nov 3, 2009 | 12:08 AM
Hobs1's Avatar
My advice is don't use cheap ball-joints unless you want some extra practice replacing them. Almost every dodge I've done has been rusted together and takes twice as long to keep from destroying the hubs(snapon makes a special tool to help with this). Good luck and use alot of anti-sieze on any metal 2 metal surfaces when you put it back together.
