Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
bleeding fuel on a CAT 3126?
Old Oct 23, 2009 | 10:09 AM
kyle_truck_pull's Avatar
Exclamation bleeding fuel on a CAT 3126?
im working on a 2000 model frieghtliner and im not to familar with this fuel system, i need help bleeding the system, what kind of injection system is this on this engine? thanks!
Old Oct 23, 2009 | 12:10 PM
Buckshotmckee's Avatar
Sma't Alec!
Crack the lines loose @ the IP, when you start getting fuel tighten them down, then loosen the lines @ the nozzles, when you get fuel tighten the lines down and you should be good to go.
Old Nov 1, 2009 | 10:51 AM
nevrenufhp's Avatar
It's got HEUI like a Powerstroke. Just bleed out the bleeder at the filter with the hand pump, then crank with your foot to the floor, just like a mekanikal injected engine.
Old Nov 2, 2009 | 07:47 AM
DieselDanBoy's Avatar
like an older powerstroke you mean? newer ones are oil pressure fired.
Old Nov 2, 2009 | 08:03 AM
nevrenufhp's Avatar
Yep, sorry...like the 7.3 P'Stroke.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
