Fuel Pressure guage not working...
Old Oct 16, 2009 | 12:36 AM
Jonny's Avatar
Default Fuel Pressure guage not working...
ok guys, after installing the column on the A pillar, the EGT's and boost work perfect, but the fuel pressure does not work at all. It worked for about 5 seconds, then refuses to function period. It has an isolator inline and it has fuel to it. I can blow in the tube to the gauge and it moves, but I can't get it to read fuel pressure. I have tried re-bleeding the side fitting, but can't seem to get it to work. I know there is some trick to getting the sucker to work, but I am totally failing. Thanks!!
Old Oct 16, 2009 | 01:12 AM
Dump the isolator and life will be good - make sure you use a needle valve to dampen pressure spikes from the VP-44.
JMO.
Old Oct 16, 2009 | 06:12 AM
tower_ofpower's Avatar
are you filling the line from the isolator to the gauge will some sort of fluid? i've heard your supposed to use anti freeze and then fleed the system so there isn't any air; if all else fails go ahead and do what the Dr said; sure beats buying a new one
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
