Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
truck wont start after taking out aftermarket cd player
Old Oct 15, 2009 | 11:16 AM
tripleAAA's Avatar
Default truck wont start after taking out aftermarket cd player
im trying to sell my 2006 duramax and i wanted to pull my cd player out and put the stock one back in, well when i which them out my truck wouldnt start. when i turned on the key it acted like the power was coming and going. i tried puting the aftermarket cd player but still nothing. PLEASE HELP!!!!
Old Oct 15, 2009 | 11:42 AM
H1 Bomber's Avatar
When you put the aftermarket cd player in the truck, did you cut the wires or did you buy the plug? Do you have any amps? Could also be a loose connection on the battery.
Old Oct 15, 2009 | 11:58 AM
tripleAAA's Avatar
i have an amp, and also check both battery. i did not cut any wire other then the remote wire the connects to the back of the cd player that goes to the amp. that was the only wire i cut
Old Oct 20, 2009 | 06:10 PM
mr.michael's Avatar
try putting the other one back in and see if it will start?
Old Nov 18, 2009 | 10:28 PM
conner's Avatar
maybe jarred a harness in the dash?
Old Nov 18, 2009 | 11:24 PM
tltruckparts's Avatar
check all your fuses. you might have snagged the REM wire on a ground enough to send a short somewhere important. and pull out the stereo and see if you snagged any harnesses anywhere else and maybe pinched them or something.
start by checking ALL of the fuses in the dash panel you never know if they route a wierd wire through something. if all appears good, start checking fuses under the hood. will the truck crank over and not start or can you not even get any power to even dome lights and that kind of stuff.
if you are having a problem even getting power into the entire electrical system check your connections on the battery. ESPECIALLY the ground wires chevys do some weird stuff when grounds arent good. make sure you check the battery to engine and battery to frame/fender ground. hope this helps! keep us updated and well try and help
Old Dec 30, 2009 | 10:23 PM
ukrmaf's Avatar
there is a cluster of ground wires way up in the dash above the glove compartment i've fixed many trucks by bypassing and grounding sowhere else.
doublehbar
13
Aug 9, 2015 12:35 AM
doublehbar
33
Jun 5, 2015 11:38 AM
dfish001
Mar 30, 2015 03:07 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
ronstop
Feb 26, 2015 09:48 AM
