black smoke
Old Oct 14, 2009 | 12:49 PM
airdog76's Avatar
Default black smoke
04 f250 6.0l black smoke when turbo kicks in. Will not smoke when throttle is given slowly.
Old Oct 14, 2009 | 04:31 PM
RSWORDS's Avatar
How about a little more info? Any mods done tho the truck?
Old Oct 15, 2009 | 08:10 AM
airdog76's Avatar
Default black smoke
no mods. just found oil in turbo & duct work.
Old Oct 15, 2009 | 07:03 PM
gradyc's Avatar
Are you using too much oil? A small amount of oil in the turbo and cooler system is normal. Some of it enters through the crankcase vent and a small amount will leak past the turbo seals. Black smoke is too much fuel or not enough air. Oil would cause blue smoke. You might have a plugged air filter. A seized turbo would also starve it for air and cause black smoke.
Old Oct 15, 2009 | 08:38 PM
airdog76's Avatar
removed wires from mass air flow sensor. no difference in engine performance. no check eng lite. no codes.
Old Oct 15, 2009 | 08:41 PM
12vcummins96's Avatar
check turbo boots what is your boost too much fuel is the cuase of black smoke
Old Oct 19, 2009 | 09:15 PM
wildbill's Avatar
Updates??
Old Oct 23, 2009 | 10:46 PM
wildbill's Avatar
Closing thread due to inactivity. Thread starter can reopen.
unluckyace
Apr 11, 2017 08:30 PM
unluckyace
Ford Powerstroke 08-10 6.4L
Sep 13, 2015 07:25 PM
wiremanWelder357
May 25, 2015 09:10 PM
ryank 199
May 14, 2015 06:41 PM
sootman
Jan 22, 2015 05:12 PM
