2000 5.9 lift?
Old Oct 7, 2009 | 08:42 PM
tooomuchpowerwanted's Avatar
Default 2000 5.9 lift?
i would like to geta lift for my 2000 5.9 cummins is extended cab 4x4 but all i a find isa 2 in. anyideas?
Old Oct 8, 2009 | 06:59 AM
maxjlone's Avatar
I assume its using the high pressure piston pump and not the low pressure diaphragm pump? Cummins's specs for each. high idle no load, minimum pressures:
diaphragm pump - 5psi
Piston pump - 18psi
landon025
Sep 8, 2015 09:21 PM
Mac1997
Jul 13, 2015 05:08 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
