how do i make my diesel smoke less
Old Oct 5, 2009 | 09:56 PM
jbradley113093's Avatar
Default how do i make my diesel smoke less
I heard that if you put a turbo it forces air into the engine and makes your disel smoke less. im about to get a chevy c/k 3500 1 ton and the guy told me it smokes at idle and smokes more when driving down the road. i was told it can be reduced by puting the turbo on and that it can be the oil rings.
Old Oct 5, 2009 | 10:58 PM
biged681985's Avatar
if its smoking at idle, and not have big injectors in it, id say it was the rings and turbo wnt help that. if its blue smoke stay away or prepare for a rebuild
Old Oct 6, 2009 | 03:48 AM
MarineOne's Avatar
Sounds like a 6.2L engine. Its normal for them to smoke a little and they carbon up really bad sometimes, plus it sounds like the owner hasn't put a hard right foot in it for a while. Doing this a couple of times from a dead stop should clear it up. Lots of black from the start as it eases into a light gray is normal. White smoke is coolant and blue smoke is oil, both of these are bad.
Kris
Old Oct 6, 2009 | 06:11 AM
It is black smoke i think. But i can't complain its a free truck.
Old Oct 6, 2009 | 02:36 PM
get it and drive it like ya stole it
Old Oct 6, 2009 | 03:32 PM
scopx's Avatar
White smoke while cranking can also mean partial or incomplete combustion (bad glow plug or dripping injector).
Blue smoke is usually oil in combustion chamber.
Black or gray smoke usually incomplete combustion due to more fuel than air (raw unburned fuel going into the air.) Can be caused by number of things, bad injector (s), injection pump set too high, high altitude to name few. Yeah, turbo will help burn fuel in combustion chamber, along with any oil.
If combustion compression engine running "right" should only see vapor trail from stacks except during turbo spool up. After its loaded, nada.
All gray-black stuff into air is unburned fuel.
Old Oct 6, 2009 | 05:09 PM
Thanks for your info. It's helping me get ready to work on it this summer when i go get it
Old Oct 11, 2009 | 11:29 PM
MarineOne's Avatar
Oh and don't put a turbo on a 6.2L engine. They have way too of a high compression ratio and you'll blow the engine.
Kris
Old Nov 25, 2009 | 09:41 AM
bigfish_Oh's Avatar
That's the first time I have heard someone wanting it to smoke less !!
Old Nov 25, 2009 | 09:44 AM
wildbill's Avatar
Smoke at idle, sounds like injectors or a head gasket issue. Monitor the coolant and oil.
