need help guys
Old Sep 29, 2009 | 08:07 PM
wolf1365's Avatar
Default need help guys
my poor old gmc has a problem, a lot like me. we go into limp mod past 65mph , boost set at 10-11 lbs , dont use vacum at all have spring kit- 20% over turbo-new heads pump-injectors – map sensor why???
Old Sep 29, 2009 | 09:05 PM
Jet A Fuel's Avatar
Welcome not sure about your issue can you be more specific.RPM's ,EGT's ect
Old Sep 29, 2009 | 09:13 PM
boys from quebec's Avatar
welcome to bombers, sure someone will help you out. Give fuller descriptions, always seems to help.
Old Sep 29, 2009 | 09:24 PM
Please do not post questions here. Scroll down to the Chevy Forums, post your question there - and someone will likely be along to help.
Here: Chevy/GMC 6.2L and 6.5L - Diesel Bombers
Old Sep 30, 2009 | 12:26 AM
01trailerpuller's Avatar
Originally Posted by Dr. Evil
x2
Old Sep 30, 2009 | 03:29 AM
97cummins's Avatar
Old Sep 30, 2009 | 05:57 AM
Jazz's Avatar
Welcome to DieselBombers
Old Sep 30, 2009 | 02:26 PM
DIESELDENT's Avatar
Welcome to db
Old Sep 30, 2009 | 06:58 PM
wolf1365's Avatar
Default dah old newbe
Well first sorry mr. Evil I am new at this. It’s a 98 GMC with a 6.2 military block, 6.5 heads [ German ] turbo has a impeller change will do 20% over stock. Injector pump stock, e max tork spring kit on waste gate [dump at 11 holds 10 lbs] stock ECM new map, stock injectors. It retards the injector pump after 65 mph till I shut it off to reset. E max has a ECM 596$ stock 180$ do I need the e tork oh it has new injector brain after market.
Old Sep 30, 2009 | 11:11 PM
millco's Avatar
Welcome, and do go over to the link the good Dr. posted. We'll see if we can't find you some help!
