Ford Excursion 99-05 7.3L and 6.0L All Discussion on the Ford Excursion with 7.3L and 6.0L Power Stroke V8 Turbo Diesel Engine. Including Bombs (Aftermarket)
sticky rear window
Old Sep 29, 2009 | 03:41 PM
joe dirt's Avatar
Default sticky rear window
anyone else have an issue with the back window/gate being hard to open??
Old Sep 29, 2009 | 07:24 PM
scrotom's Avatar
yes, other people that try to open it always think it is locked. cant have girl hands
Old Sep 29, 2009 | 08:48 PM
CSIPSD's Avatar
Wifes does it from time to time in the winter... Spray all the lock parts with some lube and it will be fine. I pulled the plastic cover off and greased everything to make sure.
Old Sep 29, 2009 | 10:21 PM
joe dirt's Avatar
its not the handle joe,..its like the rubber seal sticks to the cabin doors or something...but it doesent stick....i feel like im going to rip the handle off the glass...its got new struts and rubber...and with the handle being at eye level,..its near impossible for sindi to open byh herself...
Old Sep 30, 2009 | 06:22 PM
CSIPSD's Avatar
I know, its the same thing chelseas does. More so in the winter. Clean in there often and thats about all you can do. Need to keep the works greased is all I do for hers.
Old Oct 3, 2009 | 08:25 PM
joe dirt's Avatar
ok,..i pulled the handle and the plastic from the inside of the window,...greased everything up,...then noticed i broke 2 of the frigg'n clips off the plastic...
still did the sticking...i ended up having to loosen up the latches on the body and slide them down as far as theyd go (not much, just a "c" hair)...now it seems to open alot easyier...it was the whole glass door was dragging on the latches...
2 years of dicking with that damn thing, and i finally got it!!!
Old Feb 21, 2010 | 08:19 PM
DA BUS's Avatar
It sounds like you were just misaligned. I replaced all my exposed bolts that hold the pin guides for the individual doors with stainless steel hardware too. Mine opens up really nice anytime. I did learn one year that I shouldn't have forced the window up too high and I blew out the struts. MAN, is that thing heavy without the struts doing work!
Old Feb 21, 2010 | 08:41 PM
njneer1's Avatar
My glass sticks to the rubber seal.....have to hit it with silicone spray.......might try the latch thing too though
Old May 25, 2010 | 08:24 PM
DA BUS's Avatar
This was posted in February of 2010???? Why did I just get a post alert today??? 05/25/10???
Old May 31, 2010 | 07:39 PM
njneer1's Avatar
Weird !!! for sure !!
shingi
Off Roading
Sep 30, 2015 11:17 AM
Machinist
Jun 23, 2015 06:57 AM
southern dieselnorth zip
May 18, 2015 01:02 AM
dougcarlo
Oct 18, 2014 03:15 AM
