Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
Oil leak big
Old Sep 27, 2009 | 07:11 PM
powerstroker13's Avatar
Default Oil leak big
I just bought a used 01 7.3L Powerstroke F250 and it was leaking from an out-fitting on the HPOP so i tightened that up and now its leaking again from somewhere else and I'm not sure where its coming from exactly, I know its coming from the front somewhere near the top, any ideas?
Old Sep 30, 2009 | 10:59 AM
biged681985's Avatar
im not sure on the 01, never messed with that year yet. good luck and maybe someone else will get on and give ya a lil help
Old Sep 30, 2009 | 11:01 AM
12vcummins96's Avatar
they sell an oil leak die you pour in the oil you can get it at a parts house it will show you the leak
Old Sep 30, 2009 | 01:53 PM
toy4xchris's Avatar
that or you can give it a good cleaning and just try to keep a close eye on it. also using a dye or possibly if you can recreate the leak at idle in you drive way or something use a powder like baby powder which will soak it up instantly at the leak so you can see it better.
Old Sep 30, 2009 | 07:33 PM
tlevan03's Avatar
where is it coming from? right/left bank, front/back of the engine?the dye is a good way to find it if you cant see it, but first go ahead a clean it off with a steam cleaner or carefuly with a pressure washer and degreaser
Old Oct 1, 2009 | 07:12 PM
04redstroker's Avatar
Clean it real goog and you should be able to see where its comin from. Also, my buddy blew a HP oil line one time, and after we fixed it, it started leakin oil again a few days later. Ended up bein a diesel leak that was washin oil from the previous leak out of the valley. Only found it cuz I went over to his house and smelled the "oil".
Old Oct 1, 2009 | 07:23 PM
Big Angry Hillbilly's Avatar
Did you tighten the line, or change the o-rings on it?
Old Oct 1, 2009 | 07:25 PM
i tightened them but when i have some time im going to use the dye and find it
Old Oct 2, 2009 | 09:49 PM
Mad Max's Avatar
There is only a few places a 7.3 will leak in the valley. The HP Oil Pump, HP Oil Lines and Turbo Pedestal O-Rings. Get some Simple Green and clean up the valley real good. Start her up and see if you can find the leak. I used my camera to find my leak by sicking it down in the valley and taking a few pics...
Old Oct 7, 2009 | 11:42 AM
hey guys i found it, its an oil sensor on the head that has almost a stream of oil coming from it at 2000 RPMs, I haven't taken the sensor out to get a closer look to see whats wrong with it exactly but at least I found it.
