01 Duramax w/ low Oil pressure
Old Sep 27, 2009 | 02:04 PM
TMULLINGS's Avatar
Default 01 Duramax w/ low Oil pressure
Does anyone have anything to help??? My 01 is running rough w/ 20 psi oil pressure at 70mph / 10psi at idle. It also smells like un burnt diesel. Anyone have any ideas....anything before I have to take it to the stealer!!
Old Sep 27, 2009 | 02:08 PM
2500HeavyDuty's Avatar
check your oil i bet there is diesel fuel in it. And you are also having hard starts im guessing.
its the injectors, they have gone south, since you have an 01 your truck is past the 7 year 200k mile warrenty for the injectors though.
also it would be a good time to clean the bottom of your truck its probably soaked with diesel fuel too. and be carefull when you drain the oil there will be over 20 quarts of oil/diesel mixed in there.
one more thing, Stop driving the truck asap the diesel fuel can ruin in the crank bearings
Old Sep 27, 2009 | 02:15 PM
TMULLINGS's Avatar
It starts easy....just started doing this lasy week.
Old Sep 27, 2009 | 02:20 PM
check the oil then. the extremly low oil pressure hase happened to me 3 times because of failed injectors or diesel fuel leaking from the return lines into my engine oil.
Old Sep 27, 2009 | 02:24 PM
TMULLINGS's Avatar
oil smells like diesel, how much and how hard is it to change the injecters??
Old Sep 27, 2009 | 03:00 PM
I bought new injectors from the dealer, but any shop can usually get them from around 250 per injector + core.
I did try out a set from pensacola diesel, and i ended up having to replace my injectors 3 times in five months so i went and got new injectors from the dealer. long story short dont buy them from pensacola.
I did a short write up on doing the injectors, itl give you a clue on what to expect.
https://www.dieselbombers.com/lb7-bo...ips-hints.html
and heres a thread that helps out with some complications with an injector swap on a lb7
https://www.dieselbombers.com/chevy-...r-sleeves.html
Old Sep 27, 2009 | 04:25 PM
TMULLINGS's Avatar
How can I tell which injecter is bad?? By the way you helped me back in Feb when my CP3 went bad and was moving from Savannah to Texas. Thanks for the help!!
Old Sep 27, 2009 | 05:20 PM
balance rate test and/or return rate test. balance rate test might point you in the right direction. it can be done with a scan tool.
return rate test needs hoses and adapters to thread into the return lines to measure how much each bank is returning the most fuel and then pulling the valve covers to test each injector individually to see which one is retutning too much fuel.
but fwiw replacing all 8 woud be the best thing to do, and adjusting the valve lash while your down there
Old Sep 29, 2009 | 12:05 PM
TMULLINGS's Avatar
Well I got extremely lucky!!!! The dealer is going to warranty all 8 injecters being replaced. The cost was going to be $7k to replace them.
Old Sep 29, 2009 | 02:29 PM
very lucky
