turbo
Old Sep 21, 2009 | 11:04 PM
12valvetater's Avatar
Default turbo
well itll be a while until decide what kind of charger setup im going to run i need a DD first i just want some opinions i have an S472 that i was going to run as the bottom turbo in a twin setup with my HX35 on top but im throwing around the idea of running a single maybe a 66mm of some kind my truck is a 5 speed so i dont think it would be to hard to light a single of this size im planning on running a set of 5x.013s or 5x.014s what do you guys think i want to pull this truck and lots of places wont allow twins this is why im thinking a single now.
Old Sep 22, 2009 | 11:11 AM
NC12valver's Avatar
if just a daily driver, i would go with a 64/71/14, good spool, and still get quite a bit of hp out of it.
Old Sep 22, 2009 | 12:14 PM
yeah i want to be able to use this pickup everyday i dont pull trailers everyday but sometimes i have to so i still want decent spool a little lag wouldnt bother me that much but i want to be able to hook to the sled and make a good pull also
Old Sep 22, 2009 | 01:15 PM
mysterync's Avatar
I feel the hx35 would choke on top of a S472. I'm with Shea, Unless your dedicated to twins I would think about a single for now to play with. If you think your going with twins at some point you might run a 62/64-65-14. The 65 wheel works better with twins but is not so fun as a single charger turbo. The 71 turbine wheel will lower EGT's and create better flow in the top of the power band!
Feel free to give me a call, I'll be glad to talk it over with you!
Old Sep 22, 2009 | 03:16 PM
xzaq103's Avatar
FormerVendor
64/71 for a DD that way 1/3 of your twin setup is alread there. It will also go well with an S475 or an S480.
Old Sep 23, 2009 | 08:18 AM
94 12valve's Avatar
what class are you looking to pull? just an fyi some of the 66mm chargers will not pass the 2.6 plug
Old Sep 23, 2009 | 10:00 AM
well probly 2.6 i dont want to bite off more than i can chew right now
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
jrsavoie
Feb 6, 2015 09:44 PM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
