Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
Ratcheting open-ended wrenches and Allen bits
Old Sep 3, 2009 | 10:49 PM
Begle1's Avatar
Default Ratcheting open-ended wrenches and Allen bits
Anybody have any experience with ratcheting open-ended wrenches? I just started a job as a boat mechanic, and after two days I've realized that anything that can let me get a little bit of speed in close quarters would be worth it. Are they all gimmicks or are some of them workable?
I also need some really close-quarter Allen bits. Anybody ever see Allen bits that are about one half inch to three quarters inch long, with the Allen head on one side and a standard-sized hex head on the other side? So I could stick the Allen-headed side into a bolt, then put a wrench on the other side of the bit? So far I've had to cut down three of my Allen wrenches and I've only worked on one boat...
Old Sep 3, 2009 | 11:25 PM
94cummins12v's Avatar
i like the wratchiting wrences in some instances, speed in tight places definatly. being a diesel mecanic im up for trying anything the wratchiting wrenches are defiantly worth it
Old Sep 3, 2009 | 11:39 PM
Begle1's Avatar
Do you have any experience with open-ended ratcheting wrenches?
http://ratchawrex.com/NewBlackOxideBrochure.pdf (Like these, only these seem too rich for my blood.)
I've used Gearwrenches for a while. I'm pretty faithful in them now. I had my 5/16" Gearwrench box-end bent at least 45 degrees with a cheater bar trying to get an exhaust manifold bolt loose yesterday (the ratcheting box-end was on a cut down Allen wrench). It's only 5-10 degrees permabent now.
Old Sep 3, 2009 | 11:41 PM
not that brand im not but what i use is simalair, i love the gear drive box ends, and those have there uses but not as many in my opinion.
Old Sep 3, 2009 | 11:46 PM
How much are those?
I dont think Id spend big bucks on them.
Whats wrong with a good ratchet, a u joint and some extensions?
Might want to try some PB Blaster or a mix of ATF and Acetone...
and yes, you can get short allen bits, both with a 3/8" socket and just the 1/4" hex bit. You can get absolutely anything you want - but question is how much are you willing to pay?
Old Sep 3, 2009 | 11:51 PM
you cant get a socket in some places were you need to use an open end wrench and those speed up the process
Old Sep 3, 2009 | 11:52 PM
Begle1's Avatar
I got ratchets, U-joints and extensions. There's a lot of times when you can't get all the way around a bolt head, so a box-end or socket is useless. If a ratcheting open-end lets me get a bolt out that is only halfway open around the head, it'd save tons of time and energy. I hate having to manually reposition an open-ended wrench 60 times (I counted), 30 degrees at a time, to get a rusty bolt out of an engine mount...
What brand are yours 94Cummins? Guys on eBay want $200 for an 8-piece Ratcha-Wrex SAE set. They're not worth that unless they come with tata's.
Old Sep 4, 2009 | 12:00 AM
be honest with you i bought them from a tool truck about 6 months ago, either matco or something like that i paid $130 for them i belive there a 10 pice set, like i said i dont use them all that often but when i do they are the ticket for sure
Old Sep 4, 2009 | 12:06 AM
wildbill's Avatar
Bad thing about ratcheting end wrenches is the box end is a little bigger. Needs some room to work. Other than that, they work good. Doesn't take a lot of movement to grab a notch.
Old Sep 4, 2009 | 12:19 AM
yes that is a true statement i maybe use mine 1 a week at most
