'01 Cummins keeps dying
Old Aug 26, 2009 | 12:58 PM
01cms's Avatar
Default '01 Cummins keeps dying
I replaced the factory lift pump less than a year ago on my 2001 Cummins with dodge's in-tank replacement pump because it died and wouldn't start again. However, since then my truck has been randomly dying on me.
It usually happens at low RPM, typically as i'm coming to a stop. After a few long cranks it starts again and I have to rev it up in neutral before shifting back into drive. After that it runs strong until it dies again. This last time it died on me I noticed it surged about a quarter mile before it died at the traffic light.
My dad, who refered me to this site thinks it's still the lift pump as he's read about how the in-tank conversion pump I installed isn't a very good solution. I wanted to get some feedback before I drop another $500 on yet another lift pump.
Thanks,
Ben
Old Aug 26, 2009 | 02:21 PM
Whit's Avatar
Site Mascot
run the codes and get back with us
key on
key off
key on
key off
key on ..................read the codes in the odometer window
Old Aug 26, 2009 | 02:28 PM
wildbill's Avatar
Changed the fuel filter last??
Old Aug 26, 2009 | 02:40 PM
Fuel Pressure?
Old Aug 26, 2009 | 05:49 PM
Whit's Avatar
Site Mascot
VP death I am guessing.................wait for the codes
Old Aug 26, 2009 | 06:07 PM
DB Admin's Avatar
Banned
Thanks,
Ben
$500 for a stock lift pump
Old Aug 26, 2009 | 06:20 PM
Whit's Avatar
Site Mascot
yes...its in the tank and its also the fuel level sender////////they suck to change out
Old Aug 27, 2009 | 08:02 PM
01cms's Avatar
Ok, I got one code from the odometer P1693. I've been pretty good about changing the fuel filter, it's been about 3 months now on this one. I'll probably change it today. At the moment I don't have any fuel pressure readings.
Btw, I never get a check engine light when it fails on me. That may effect the codes right?
I checked the fuel pressure thanks for the suggestion, and it's only 10 PSI. Looks like I'm going to have to buy one of those FASS pumps because mine isn't doing the job. Yet another testimony that the factory's in tank replacement pump is garbage. It lasted less than a year and who knows how long i've been running on only 10 PSI , it may have never worked correctly. Thanks for the help!
Old Aug 27, 2009 | 08:24 PM
key on
key off
key on
key off
No No No - you need to use an OBDII scanner....
Take a look at his post - he got P1693 which is the companion code - you need the scanner to see what other code(s) are there.
Old Aug 27, 2009 | 08:26 PM
[/size][/color]
10 psi is acceptable if its measured at wide open throttle (WOT) - but its not acceptable at idle.
This is just a guess - but your VP-44 might be in need of replacement.
FYI, Airdogs are cheaper than the FASS units and they have a lifetime warranty on the pump.
