Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Hydrogen
Old Aug 24, 2009 | 03:20 PM
cumminthru's Avatar
Default Hydrogen
looking for info on homebuilt hydrogen systems as a diesel component. ANy thoughts.
Old Aug 25, 2009 | 03:12 PM
outlaw1_gt's Avatar
Does Water For Gas Work in a Turbo Diesel?
Old Oct 7, 2009 | 07:12 PM
1kennyg's Avatar
Hydropowercar
i started here i gotta 6pac air induced home made hydgen you can buy on line ..
most countrys they been in use our fuel was cheap we did nt care
check out u tube
Old Oct 8, 2009 | 04:23 PM
millco's Avatar
There are some large threads around the internet too.... I would like to find someone local who has done it and had results! If a guy could actually get it to work like some say, it would be great!!
Old Dec 13, 2009 | 06:01 PM
weldhaus's Avatar
Built a Hydrogen assist system consisting of 3 cells. Drew too many Amps with 12V across each cell. Had an alternator fire. I suspected current draw to be over 40 amps per cell with my configuration. I haven't had time to mess with it since fire. Been told that running with 4V across each cell should give same amount of gasses produced. Also was informed they do work just difficult to get electrical current draw figured out, current increases over time as electrolysis heat up solution and reaction rate increases. I didn't recieve any noticable MPG increase though. I was running WVO also at the time.
