6.2 pump on a 6.5 needs help
Old Aug 21, 2009 | 07:14 PM
bulldozer's Avatar
Default 6.2 pump on a 6.5 needs help
I have a 1998 gmc 3500HD and after a few years of pdm and other electrical problems causing my truck to be unreliable, I want to convert my truck to a mechanical pump. What problems will I encounter and what parts will I need? I have already located a 6.2 pump that will be rebuilt to go on a 6.5. It looks as if the thermostat housing will be in the way of the throttle cable. If anyone has done a similar conversion the help would be appreciated.
Old Aug 21, 2009 | 09:46 PM
Woody35's Avatar
it is possible and its not too hard but i dont know the exact details. there is a book out there from a guy that did this swap in the 90's but i dont know the title. i do know you need to convert the accerlator pedal from electronic to mechanical linkage. also if you have a manual its a lot easier to do the swap compared to if you got the 4L80E auto tranny.
Old Aug 21, 2009 | 10:28 PM
bulldozer's Avatar
yes i have a manual trans. that book would be great. just trying to get everything together to make the swap and trying to piece it together and avoid the pricey "kits"
Old Aug 22, 2009 | 08:06 AM
red's Avatar
red
I have made this conversion on my 96 3500 crew cab no 1 you must aquire inj lines
off the 6.2 the ones on the electronic pump won"t work. Next you must put an after
market cruise control unit on. The linkige I built not to complicated just remember the trans if auto shifts off the reostat on the accl pedal so you must be able to adjust
it thats is why i used a rod instead of cable.
Old Aug 22, 2009 | 11:16 AM
dragogt's Avatar
I'm curious about this as well, is the '94 in my sig a "drive by wire" as well?
Old Aug 22, 2009 | 09:02 PM
Woody35's Avatar
yup it is. only mechanical 6.5s got linkages for accerlator pedal
Old Aug 23, 2009 | 01:28 PM
red's Avatar
red
Im not sure that the 94 had the electronic pump I took 23 wires off the system and replaced them with 2 wires just made things a lot simpler except the timing issues I
am having trying to find a timing light.
Old Aug 23, 2009 | 03:06 PM
Woody35's Avatar
yes the 94 was the first year for the electronic 6.5. 93 was the last year for the mehanical 6.5.
Old Aug 24, 2009 | 06:02 AM
dragogt's Avatar
Ant that 'bout a....
What all did you remove?
That's what I figured.
Old Aug 24, 2009 | 12:00 PM
red's Avatar
red
I removed allthe wiring to the electronic pump except 1 which fed the fuel sel
I added 1 wire to the pump cold start advance so far haven't really needed it
here in Tenn
