06 dodge fuel rail problem
Old Aug 15, 2009 | 06:56 PM
bmcoftexas's Avatar
Default 06 dodge fuel rail problem
smarty turned on level 5 other than that its stock my problem it threw a hpcr code (high pressure commen rail) i cleared the code and removed the smarty back to stock drive about another 25 miles and it threw it again. i get home and remove the valve cover and the number 1 injector is spraying fuel and it has pushed all my oil out of the rear main seal so i change the injector and oil drive 100 yards and it throws it again i pull the valve cover again and number 4 is smoking white what do i do??????????????
Old Aug 15, 2009 | 07:03 PM
wildbill's Avatar
Going to have to replace all the injectors. Also, going to need a new pop off valve.
Old Aug 19, 2009 | 03:44 AM
wildbill's Avatar
Going to close, cause he also failed to disclose any performance parts.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
