Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Synthetic Oil
Old Aug 14, 2009 | 09:17 PM
Countryboysfords's Avatar
Default Synthetic Oil
How much would synthetic oil help out a 7.3 idi ?
Old Aug 15, 2009 | 10:07 PM
Heath's Avatar
Authorized Amsoil Dealer
What are you looking to improve?
Fuel mileage? mabye a little.
Cooler running..probably some
longer drain intervals...most definitely
Syns can offer some advantages. Depends on what you are looking to gain. If your'e one to change oil every 3-5k no matter what oil, then the gain is minimal, but possible.
Old Aug 19, 2009 | 10:20 AM
Deezel Stink3r's Avatar
-Less Engine wear than mineral oil
-Thermical heat stability, if you are hard on your engine
-engine is much cleaner inside, no residues or contaminants inside the engine. Usually if you wipe off the oil, the metal is clean.
-Look at the Synthetic Oils like an insurance without the hassle of an agent.
-Maybe you will gain a 2% up to 3% mileage improvement
In my opinion reasons enough to go with Synthetics, if you don't mind the extra costs.
Old Aug 19, 2009 | 12:06 PM
ltr450's Avatar
go with amsoil it is the best
Old Aug 19, 2009 | 01:16 PM
Johnny Z's Avatar
All i run is Amsoil,in everthing I own,100% of the time
Old Aug 20, 2009 | 12:16 AM
01quadcab's Avatar
me too put it in my air compressor too and now the thing runs great in winter too quieter on top of that.
Old Aug 21, 2009 | 02:00 PM
dozerboy's Avatar
The best for what it certainly isn't the best oil across the broad? Amsoil is a good oil but some of you need to step way from the koolaid.
Old Aug 21, 2009 | 10:33 PM
sidekick's Avatar
amsoil by far
Old Aug 21, 2009 | 10:47 PM
Buckshotmckee's Avatar
Sma't Alec!
I'm a Mobil 1 fan as far as synthetics go. I got better protection from the Mobil then Amsoil.
Now after running synthetic oil vs dino, the things I noticed was longer oil change intervals and about a $15.00 savings on oil changes.
-3 gallons of synthetic, $100.00 = 15k oil change intervals, oil filter $6.00
-3 gallons of Delo 400, $36.00 = 5k oil change intervals, oil filter $6.00x3 = $18.00
And then there's your time of doing the oil change.
Old Aug 23, 2009 | 03:13 PM
Cowboy_Customs's Avatar
Ran Ams in my '92 IDI and my '93 Cummins, seemed to start better in the winter, and was a touch quieter. Not to mention the extended drain intervals, and the savings doing so.
vin_diesel
Sep 15, 2015 11:25 AM
1stgenSWB
Aug 13, 2015 12:19 AM
soco
Jul 27, 2015 06:06 PM
sjslhill
Jul 22, 2015 01:02 PM
coors_man_2005
Dec 15, 2014 10:23 AM
