Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
amp cuts off
Old Aug 10, 2009 | 01:13 AM
skyjacked84's Avatar
Default amp cuts off
my amp cuts off when the vol is at like 20. its a 4ch JVC amp. i had it hooked up to my door speakers. but i hooked the door speakes up to the cd player an the amp to my subs an it still cuts off when i turn it up past 20. any sug?
Old Aug 10, 2009 | 01:20 AM
coyropin's Avatar
is it overheating hot to touch,when does it do it like after long period of time then put it at 20 or just when you put it at 20, might be two little power wire, is it bridged
Old Aug 10, 2009 | 01:41 AM
nope not hot. only when i turn it up past 20. yes its bridged. the wire looks older. an its 8ga i think.
Old Aug 10, 2009 | 01:49 AM
coyropin's Avatar
how big of in amp is it, try and unbridge it just hook it +- and see if that helps maybe the bridge part is fryed up or your pushing to big of a sub for the little amp
Old Aug 10, 2009 | 01:51 AM
600 watt
not sure as the subs, i know they are 10" kicker comps
Last edited by skyjacked84; Aug 10, 2009 at 01:51 AM. Reason: Automerged Doublepost
Old Aug 10, 2009 | 02:12 AM
coyropin's Avatar
well that should push the sub thats what i had before try and un bridge it and see if it still does it then im not to sure
Old Aug 10, 2009 | 07:26 PM
CAMSHAFT's Avatar
Where is the gain set at on the amp?
Old Aug 10, 2009 | 10:23 PM
all the way up i think
Old Aug 11, 2009 | 04:42 AM
bryson's Avatar
Subs could be wired incorrectly...are they wired series or parallel? Dual voice coil or single? Ohms?
It could also be a bad voice coil that is grounding out when you turn it up.
Either way, you need to use a good multimeter and do some investigating.
Old Aug 11, 2009 | 01:12 PM
its not only with the subs. when i had my door speakers wired into the amp it would also cut off when i turned it up past 20
