scantool?
Old Aug 9, 2009 | 06:48 PM
hotrod0872's Avatar
Default scantool?
what kind of scantool do i need to adjust pump timing?where can i get one?
thanks for the help!
Old Aug 9, 2009 | 11:01 PM
Woody35's Avatar
you can use a autoengunity and tech2. tech 2 is GMs own scan tool which is mega bucks. autoengunity is the easiest to use and there is one more but i cant remember the name. tech 2 you can find on ebay and autoengunity you can order from their website.
Old Aug 10, 2009 | 12:50 AM
Turbine Doc's Avatar
need more info about the truck, especially year, ones Woody mentioned won't work for you if yours is OBD-I year truck
Old Aug 10, 2009 | 02:15 PM
Woody35's Avatar
top right corner it says its a 1996 3500. that is a obd 2 if im not mistaken
Old Aug 12, 2009 | 03:21 PM
Right you are, on both counts as this poster slinks off to a corner to .
Is it auto or maunaul trans, that ain't posted in top rite corner not that it has anything to do with timing l had to recover a little pride
So goes the folly of being an infrequent visitor, one gets used to automatically looking for just signature information at the bottom you find at most other sites, you overlook forest for the trees.
Now that we/I know the flavor of 6.5 another tool that will work and easiest to come across is a Snap-On scan tool most shops have one of those, were we a little closer he's one end of Ms I'm at other I'd have him swing by and we would use mine.
Car-Code is possibly another you were thinking of Woody it is a software scanner you put on a laptop to scan/tweak with.
Hot Rod you'll also want the IP wrench set that makes life so much easier.
Old Aug 16, 2009 | 09:01 AM
hotrod0872's Avatar
thanks for the help guys!my buddy has a snapon!
Old Aug 17, 2009 | 06:09 AM
DieselSlug's Avatar
DOnt the snap-on scanners sometimes come up with funky readings sometimes??? I thought i heard that somewhere...
Old Aug 17, 2009 | 02:13 PM
Woody35's Avatar
if td is using it i assume its a good scantool
