Injectors... How much hp
Old Aug 9, 2009 | 12:12 PM
1999 Sport Cummins's Avatar
Default Injectors... How much hp
well as of now ive almost got every thing i wanted on my truck befor i got injectors...in the sig... except the boost elbow.. oh well. I am getting closer to geting a set of injectors and i needed to know yalls opinon on what size injectors i need to stay safe with my stock turbo... i do hot rod it a little every now and then and maybe 1 or 2 times a years i will pull heavy louded trailers like a 42ft tandum daul loauded down with hay.... and a bumper pull every once ina while... i got a 3 or 3 ina half in pipe but im panning on upgrading to a 4 or 5in turbo back
Oh Aslo what is the Safe range on egts???? Im running 600 Degrees now
Old Aug 9, 2009 | 12:24 PM
ltr450's Avatar
i thing you would be fine with the 100s you want to put in i've seen people running 150s on stock turbo. that truck of yours looks sharp all white how did you get your tow mirrors white
Old Aug 9, 2009 | 12:32 PM
krylon fusion spray paint the cheap way works good to.. its meant to bond to plastic but the sucky part was havin to wait 7 days after i painted them to drive it.... had to wait bc instructions say that its chip proof after 7 days
Old Aug 9, 2009 | 12:33 PM
You would be fine with 100's or 150's until you start to tow a heavy load. Id do some 40-50hp's. Now if you upgrade your Turbo then thats a different story.
Old Aug 9, 2009 | 09:12 PM
turbo20psi's Avatar
Last sat. I towed a backho 25,000 to 26,000 pounds for my buddy. Water line problems other story.I have fireball 150s phat shaft turbo 62/14 my egts were 1000 to 1100 degrees before turbo with 4.10 gears. With a tow tune on the smarty no edge comp.Didnt even know it was back there.I hope this helps.
Old Aug 9, 2009 | 09:22 PM
Umm thanks alot I'm mean now I know that 11000 should be safe but my egt is tapped after tha turbo
Old Aug 9, 2009 | 09:41 PM
turbo20psi's Avatar
No problem, this was a first towing this much but it worked out.
Old Aug 9, 2009 | 10:09 PM
Those Fireball's are a very clean injector. Ive had customers compare them to Mach's.
Old Aug 14, 2009 | 11:57 AM
sstockton's Avatar
100's should be just fine. My friend runs Jammer 3's in his 01 auto with an edge comp, and an hy35 and has no problems with it. He used to tow a 46' enclosed 5th wheel hauling cars around the western states with it, and never had any problems. With the manual, if you drive sanely when towing you will be just fine.
Sean
Old Aug 14, 2009 | 11:59 AM
mysterync's Avatar
figure a 300-400F drop from manifold to downpipe.
