would like more power
Old Aug 8, 2009 | 06:46 PM
captain_stabbin's Avatar
Default would like more power
i currently own a 94 cummins an i only have 4 inch exhaust an fuel plate with stock turbo with 30lbs also have 200 shot of nitrous but seems to not work like im not gettin enough fuel not sure any help would be greatly appreciated
thanks josh
Old Aug 8, 2009 | 07:10 PM
94 12valve's Avatar
well first off you do not need a 200 shot on a stock turbo that will prob lead to a big kaboom ... and with just a fuel plate the stock turbo should be all the air you will need. do you have an auto or a stick?
Old Aug 8, 2009 | 07:12 PM
5 speed
Old Aug 8, 2009 | 07:16 PM
94 12valve's Avatar
ok so you have a 175 hp pump ( same as me) how much power do you want?
Biggy B's Avatar
it all depends on how much money you want to spend
Old Aug 8, 2009 | 07:20 PM
i really am not sure what fuel plate i bought but i do member it said 100 to 150 gain i would like to make 400 hp no more
i want to get bigger injectors but not sure what size to get, and also i noticed that they offer delivery valves for the pump too
Last edited by captain_stabbin; Aug 8, 2009 at 07:20 PM. Reason: Automerged Doublepost
Old Aug 8, 2009 | 07:25 PM
94 12valve's Avatar
ok that is very easy ... first find some injectors out of a 97 - 98 5 speed truck with the 215 hp ppump, along with a set of 181 DV's, a set of head studs, set pump timing to 16- 17*, 3,000 gov springs, an intake, and an hx 40 or a 62mm charger your choice.
also your gonna wanna upgrade the clutch the stocker should hold but once it starts to slip its done.
forgot to tell you to mod your afc and add the 2095 mack rack plug
im sorry but i have no clue what 181 dv's are
Old Aug 8, 2009 | 07:28 PM
94 12valve's Avatar
they are the stock delivery valves out of a 215 and 180 hp ppumps ... you have 131's in your 175 they also came in the 160 hp ppumps its a simple and very good upgrade
Old Aug 8, 2009 | 07:30 PM
kewl thanks
and all this can be done with a stock intercooler
Last edited by captain_stabbin; Aug 8, 2009 at 07:30 PM. Reason: Automerged Doublepost
