06-07 LBZ Performance Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines Related To Performance And Longevity
5 inch exhaust??
Old Aug 6, 2009 | 10:59 PM
Snowman's Avatar
MR.3K
Default 5 inch exhaust??
I know there are companies that make full 5inch exhaust and full 4inch, but i was looking for a full 5inch turbo back and then into stacks??? But also wondering if its worth getting the 5 or should i just go 4 then to dual 5inch stacks???
just cause MBRP makes a 4inch turbo back to dual 5inch stacks. Would that kit be sufficient enough??
Old Aug 6, 2009 | 11:05 PM
cmtowing7.3's Avatar
i have 4'' in to 5'' side pipe but i just took down the stacks.. 4 in to 5 is good enough my truck is a 93 idi 7.3 srw 4 door 5 spd stick 2 wd
Old Aug 9, 2009 | 06:50 PM
dozerboy's Avatar
4" is more then enough, but IMO get 6" or 7" stacks.
Old Aug 9, 2009 | 07:07 PM
Dual 4" out the sides with 6" SS Tips
Old Aug 9, 2009 | 08:12 PM
Snowman's Avatar
MR.3K
i scored a set of 5 inch mitercut stacks for rebuilding a guys engine. just not sure if i want to install them.
Old Aug 11, 2009 | 12:04 AM
dmaxman06's Avatar
i'm partial to 4 inch down pipe into a 5 inch stack or 6 inch but i'm still rocking passenger side exit behind the tire cuz i love echoing off wall,houses,guard rails, or people if there in the way hahaha i know i'm dick
Old Aug 11, 2009 | 12:37 PM
Tyler@MPF's Avatar
I would go 4" exhaust to 4-6" stacks. If I can help let me know.
Old Aug 11, 2009 | 12:53 PM
Snowman's Avatar
MR.3K
I was thinking of going with a 4inch down pipe. Then i'll prob go with the stacks. If i need anything i'll maybe give u a shout Tyler, thanks.
Old Aug 11, 2009 | 01:59 PM
crzycowboy's Avatar
Grand Rock Tech. Support
Most common set ups are 4" to the y-pipe. From that point it makes the transition to the stacks. Our kits are 4" under the bed, with a 5" y-pipe. The transition is at the bottom of the y-pipe, so when you look in the truck bed you see nothing but 5" plumbing. However if you look under the truck you will see nothing but 4" exhaust.
Old Aug 12, 2009 | 01:04 PM
Snowman's Avatar
MR.3K
Thats wat i was looking for. But i'm not sure if i can bring myself to cut a hole in my new boxliner!! I'm not sure what i'll do!!
