Traction Bars
Old Jul 29, 2009 | 09:48 AM
rkadcock's Avatar
N.M. Bombers Director
Default Traction Bars
What would be a good set of traction bars for a 97 Dodge 2500 that is going to be used sled pulling. I have a 2" Pro Comp leveling kit on it with Air Lift air bags in the back.
Old Jul 29, 2009 | 11:25 AM
12valvetater's Avatar
you can make a set for a lot less than buying 80in long is what most ext cab long beds use
Old Jul 29, 2009 | 11:48 AM
TwinStackPete379's Avatar
I just helped dodgehunter84 make some for his truck. they got 4 hooks on em and never had a problem. It was pretty slick how he made them. PM him and he woiuld be glad to get you a parts list. he maybe had 80 bucks in them. The reason being he got 4 hind joints (sp) for tractor 3 point hitches at rural king.
Old Jul 30, 2009 | 09:52 PM
tsambo212's Avatar
I would make them using spring hangers off another truck and drag link off a semi truck to adjust them.
Old Jul 30, 2009 | 10:59 PM
rkadcock's Avatar
So I spent about half my day with a couple friends making a set of bars to get me through the pulls this weekend. I'll take some pics tomorrow once we finish. But we got 80 steel bars from my work and we drilled pin holes through both ends of the bar then we bolted on the 3 point hitch (thanks twinstackpete379) hook ups from an old Ford 8N tractor.
Tomorrow I'm going to get some heavy duty bolts from work and hook up the bars. Once I get back from Denver on Tuesday, depending on how these bars hold up, I may keep them and get them painted and modify them for good looks or if it all goes to hell, back to the drawing board.
Old Nov 5, 2009 | 08:30 PM
BD Cummins's Avatar
does anyone have any pics of the traction bars that you have made and all the parts that you used
Old Feb 13, 2010 | 04:31 AM
Spurrit's Avatar
So, say a guy(me) is a total newb; WTF are traction bars?
Old Feb 13, 2010 | 05:26 AM
Jazz's Avatar
Traction bars help maintain correct pinion angle and eliminate leaf spring wrap
caused by the torque of acceleration for smoother take-offs,
longer U-joint life, reduced clutch chatter, firmer shifts with any
transmission and no damaging wheel hop - all while transferring
more engine power to the tires for better mileage & a lower E.T.
Besides increasing towing and load capacity, they also function
as anti-roll (sway bar) devices during a turn, while giving a more
stable ride over potholes, railroad tracks and washboard roads.
traction bars
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
rvlmeyer
Feb 15, 2015 03:36 PM
Cumminsfreak24
Jan 21, 2015 09:10 AM
carid
Oct 28, 2014 08:42 AM
