5" MBRP Down Pipe Back 6" tip Build Thread
So here are some photos...
Setting up in the garage!
Removing DPF module Flex hose from controller...
Removed bolts at Muffler... I took the time to spray down all the bolts with PB Blaster a couple days in advance so those bolts were a breeze!
This is the bolts at the other end of the muffler and this section is the Particulate Filter!
This is the removal flange at the down pipe being removed!
Muffler goes down!
Obviously there was some cutting involved! :P
Those lines above the flange are part of the DPF!
More Pipes!
This +....
Muffler goes down!
More Pipes!
This +....
This= Weight reduction
Downpipe
[/QUOTE]
The last pipe that went over the axle and around the tire I had to cut so that the tip would site the way I wanted it!
http://s166.photobucket.com/albums/u103/dietz4ibanez/?action=view¤t=MOV03593.flv
It took a little tweeking but I am happy with this!
I tried to do the best that I could with the weld cause if it looks nasty and you are looking at it your going notice it... So I thought this weld was pretty descent..
Downpipe
[/QUOTE]http://s166.photobucket.com/albums/u103/dietz4ibanez/?action=view¤t=MOV03593.flv
Nice looking setup. Your gonna love it. Just wondering why you cut it up? Should have came out with a bracket off the the allsion removed and the spare tire dropped. So what tuner you use to remove the DPF out of the ECM?
Brian
__________________
2007.5 Chevy Silverado 2500HD LTZ 4x4 D/A LMM 365hp/660tq stock, CC/LB Summit White stock 265 tires/17" wheels, DashHawk II with external EGT sensor in a custom painted Edge Dash Pod, PPE air box mod, Stanadyne year round, Line Of Fire, and new LMM OS.
Upgrades: 5" MBRP Turboback 6020AL from Nate at Home, EFI-Live V2 from Nick at Duramaxtuner tunes Twins | DURAMAXTUNER.COM, EGR Blocker from Diesel Performance: Discount Truck Accessories & Performance Parts, Buy Chevy, GM, Dodge & Ford Truck Parts, Air Intake Filters & Exhaust Systems, Fuel Tanks, Mounts, Gauges & Injectors Online and tuned by Nick from DuramaxTuners, an Airdog 150 Lift pump and Labonte Water/Meth Stage III from Tyler at Meyer Performance & Fabrication, LLC. - Home.
Good Mileage with Nick's tune but maybe if I kept my foot out of it might be a bit better but that would be no fun.
Future: Rocker Pods ROCKER POD Cargo Step from Ultimate Truck Gear
Configure your FlashScan V2 the way it should be http://www.dieselplace.com/forum/sho...57#post3201357
Remember if you want to play you got to pay.
UA Steamfitter, Local 136 Evansville, IN
Brian
__________________
Brian
__________________
Brian
__________________
Yeah your right! I did this at like 3am in the morning! So thinking clearly was not an option... And at the time zipping through the pipe at the muffler looked like an easier option than lowering the spare tire and man handling that piece!
On another note wish I would have looked at using a jack to hold the tranmssion in place while dropping the crossmember and easily pulling out the cat down pipe section.. I thought that I could easily zip through the pipe with the reciprocating saw until I found out that is was double wall by the cat...
But thats how you learn.. Kinda went into this before reading anything about it! Just saw and heard videos of the amazind sound! I went with the EFI Live Tune and loving it!
Brian
Brian
__________________
Brian
__________________
Do you have any Exhaust Clips?
This is where mine are!
https://www.dieselbombers.com/chevy-...ust-clips.html
Last edited by dietz4ibanez; Jul 18, 2009 at 06:16 PM. Reason: Automerged Doublepost
Never had to remove that bracket off the transmission. Just a bracket off the rear of it was all that was needed. A support for the exhaust was all it did on the stock system.
Kool on the EFILive. I love mine through Nick from Duramaxtuner. No clips of my exhaust. To me most of the clips just don;t give it justice. Sound off computers can be bad.
Brian
__________________
Brian
__________________
Brian
__________________
Brian
__________________
