what does lazer cut delivery valves do?
Old Jul 16, 2009 | 09:05 PM
jaybuller's Avatar
Default what does lazer cut delivery valves do?
I got a quote from a shop on some pump timng, and a few other things. They recomended for me to install lazer cut delivery valves. What do these do? What do they help? and is 290 a good price for them? thank you
Jay
Old Jul 16, 2009 | 09:44 PM
Cummins97's Avatar
My Opinion..... DONT DO IT!
They add a LOT more fuel and egts sky rocket...
Just my opinion... The choice is yours.
Old Jul 16, 2009 | 10:59 PM
rkadcock's Avatar
N.M. Bombers Director
I agree on not doing laser cuts unless you plan on going to some sled pulls. Fill out your signature so we know what you've done to your truck, that'll help alot. I would look into doing 191s which is a big difference than the stock DVS
Old Jul 17, 2009 | 01:48 AM
davo79's Avatar
X3 laser cuts are great if you're running a huge set of twins have a block girdle 14 mm main studs and head studs billet rods pistons pushrods. A huge cam big *** injectors injector lines and have a pump built to use them. So yea 191s or even 181s do the job just fine
Old Jul 17, 2009 | 02:28 AM
I would think about going to a different shop for the pump work. Delivery valves are just about the last thing to do....and lazer cuts are out of the question for you at this stage of the game.
Old Jul 17, 2009 | 04:03 PM
jaybuller's Avatar
I asked him in an email what the lazer valves do and here is what he said..
"Delivery valves are the 6 little 'outlets' from the injection pump...and they can be a restriction between the pump and the injectors. Basically, by swapping out the DV's, you are ensuring that your stock injectors are the restriction (as they should be) and not something between them and the pump. governor springs, advancing the pump timing, a ground fuel plate, should be "first"...but the delivery valves do wake them up a good bit more, and they are pretty "cheap".
Old Jul 18, 2009 | 12:15 PM
94 12valve's Avatar
you have a long way to go before your 181 dv's become a restriction many have made over 500 rwhp with 181 dv's
Old Jul 18, 2009 | 01:02 PM
You will just gain heat and smoke.
Old Jul 18, 2009 | 01:09 PM
jaybuller's Avatar
OK so the lazer dv's are out. Now i need to find another diesel shop that knows whats goin on with these trucks. The shop i got this from deals mostly with the 7.3, and thats how i knew about them, they did awsome on my 2001 ford 7.3. but he did say hes only messed with a couple 12v's..
Old Jul 19, 2009 | 09:44 PM
All DV's are going to do is add lots of heat
Hutch58
Mar 21, 2015 12:13 AM
countryboy040993
13
Mar 5, 2015 08:58 PM
Feb 18, 2015 01:00 PM
