98.5-02 Cummins 24V 5.9L VP-44 Tech Talk Tech Articles for the 2nd Generation Cummins 24V 5.9L VP-44 Engines.
APPS
Old Jul 12, 2009 | 06:37 PM
zrendel's Avatar
Default APPS
im needing a quote on a apps for a 02 Dodge 2500 5.9l Cummins TD. its automatic transmission.
Old Jul 12, 2009 | 06:55 PM
DB Admin's Avatar
Banned
have you tried resetting it there 2 ways to reset it , one requires a multimeter
Old Jul 13, 2009 | 06:38 PM
zrendel's Avatar
well heres my problem. when the tranny would go to shift into OD it would shift back and fourth from my last gear to OD. it did that around 45 to 50 mph. so we reset it once by unhooking the batteries and using the foot feed method and that fixed it. then the problem came back so we checked to voltage and it was perfect. right where it needed to be. but last night i unhooked the batteries and reset it again using the foot feed and it works now. but heres the thing i never had my batteries unhooked or anything like that between when it was working and when it started acting up. so what do you think it might be?
Old Jul 13, 2009 | 06:56 PM
DB Admin's Avatar
Banned
I had to isolate my apps wires from the main wiring harness to keep it from doing that , my truck is also a 2002 cummins
Locate the APPS wires
Seperate the Group of wires that are twisted together ...thats the apps Single going to the ECM ,,, it getting interferace from the other wires in the Split loom ...
Here it is pulled out of the Loom Below the ECM ,,
Note Remove Air Intake Manifold and Fuel Filter Housing for access
Here they are going into the ECM connection
Just Pull this set of wires away from the other and run them in a separate split loom ,,,,then poak all the other wires back in the OEM split loom and put it all back together
Good Luck and if your still having trouble Call 1-740-743-2100 ask for Brian and tell him whats going on
DM
Old Jul 15, 2009 | 05:44 PM
zrendel's Avatar
ok will do thanks im probably going to do that this weekend.
Old Jul 17, 2009 | 09:56 AM
gosperformance's Avatar
FormerVendor
Interference is a major issue on these things. I will shoot ou a PM in the mean time for the apps.
burndiesel
10
Feb 7, 2023 01:15 AM
crazycooter
Sep 22, 2015 08:43 PM
Craigdegolier
Jul 20, 2015 04:46 AM
jeremiah1
Jun 21, 2015 06:45 AM
J. Nick
Apr 25, 2015 05:01 PM
