trucks stalls while driving
Old Jul 10, 2009 | 12:45 PM
wvsmoker's Avatar
Default trucks stalls while driving
ok another problem so ill be driving and my truck shuts off but not all the way just long enough to make my radio shutoff and turnback on even the lights on the dash light up like you just started the truck its weird cause once u drive it for a few minutes its quites any help greatly appr!!!!!!!!! and i got plenty of fuel pressure bout 20lbs
Old Jul 10, 2009 | 01:15 PM
Jazz's Avatar
Some kind of short or something. But after you drive a while it doesn't do it?
Old Jul 10, 2009 | 02:21 PM
Sounds like a electrical short some where.
Old Jul 10, 2009 | 08:17 PM
HoodStacked's Avatar
Banned
Either Electrical Short or I've seen this be caused by an injection pump beiginning to fail.
Old Jul 10, 2009 | 10:52 PM
wvsmoker's Avatar
yeah its fine after like 5min the only thing i recently did was put a airdog on
Old Jul 10, 2009 | 11:23 PM
skinnysfd's Avatar
Kinda sounds like a bad ground somewhere?
Old Jul 10, 2009 | 11:29 PM
coyropin's Avatar
check you battery cables make sure there tight, also i found out the hard way do you tilt your steering wheel alot if so might my power cable to my key switch broke there that was a day finder right there. just pull the bottom plastic part off and check you red wire there make sure it is not loose there is also a recall for the power disterbution (cant spell) box the fuse box under the hood make sure there tight
Old Jul 11, 2009 | 10:31 AM
wvsmoker's Avatar
does anyone think it could be my baterries cause there getinn a lil slow crankin
Old Jul 15, 2009 | 08:29 PM
wildbill's Avatar
Slow cranking is usually due to bad batteries. Be sure to have em load tested.
Old Jul 16, 2009 | 04:45 PM
wvsmoker's Avatar
so i just got two optima redtops cranks like hell now but sumtimes it will still buck.its so weird ill be drivin then it will buck once
