How to get into the instrument Panel?
Old Jul 6, 2009 | 08:53 AM
mmartin09's Avatar
Default How to get into the instrument Panel?
Somehow, the back side of the clear plastic that sits in front of the instrument panel is dirty and/or scratched. I would like to take that piece of plastic out and clean it or replace it. Is that even feasible? If so, could someone point me to a place where I could get a diagram of the instrument panel and instructions on how to get into it.
Old Jul 6, 2009 | 12:22 PM
FarmDiesel's Avatar
I would like to know this too I have been thinking about a custom gauge cluster or something...
Old Jul 7, 2009 | 10:32 PM
mmartin09's Avatar
Anyone?
Old Jul 7, 2009 | 10:43 PM
cbrahs's Avatar
1. remove the knee bolster (panel just under the steering column)
2. depending on the center console that you have, you need to remove the bezel around the stereo.
3. remove the side panel (as seen when opening the door. it is just snapped in and is a bit tough but does come out.
4. there are a few screws that hold the cluster bezel in place, remove them to get the bezel out. Then you are on the downhill stretch.
while you are there, you can also change the bulbs out to a colored bulb if you want. might as well if you are even thinking about it while you have the cluster removed.
install in reverse order
have fun!
Old Jul 8, 2009 | 01:03 AM
FarmDiesel's Avatar
If i put a blue bulb it would be blue? Its not the panel itself that controls the color?
Old Jul 8, 2009 | 10:05 AM
cbrahs's Avatar
according the dealer connect you can change the bulb so I am going to go on a limb and say if you put in a blue one it will be blue
Old Jul 8, 2009 | 12:41 PM
FarmDiesel's Avatar
It will match my aftermarket sterio then. As well as my Edge.
01stroker7.3
Sep 24, 2015 07:46 PM
Diesel_Dad
Aug 18, 2015 11:50 PM
mike350fordpower
Jul 17, 2015 08:51 AM
gp98
Mar 30, 2015 11:03 AM
