LEVELING KIT
Old Jul 5, 2009 | 04:37 PM
GOOD OL' BOY's Avatar
Default LEVELING KIT
I'm lookin for a leveling kit for the front of my 2001 cummins 2wd. So far i've found some made by daystar. Anyone know of any others? Or if daystar is worth a damn. thanks
Old Jul 5, 2009 | 04:39 PM
Daystar makes good kits
Old Jul 13, 2009 | 11:44 AM
Nor-Cal Nick's Avatar
Really if you are looking at a spacer kit the daystar is a good product.
Old Jul 14, 2009 | 07:44 PM
Slo_5.9's Avatar
Daystar is the only one that I know about also. Because I am using their kit. 1 1/2" If you buy their 2 1/2" kit, you will need to buy aftermarket upper control arms. NOT WORTH IT..... Mine is also a 2wd dually. Hope this helps
Old Jul 14, 2009 | 08:51 PM
bryson's Avatar
The 2wd duallies are a beam axle with 4wd suspension, right...?
If so, TeraFlex, Tuff Country, SkyJacker, Rancho and a bunch of others make cheap leveling spacers... IIRC, TeraFlex is discontinuing theirs, so you may be able to find a set for cheap ($70 or less.) Call my good friend Carl at TeraFlex PLUS and he can take care of you - 801-713-3314.
But, yes, the Daystar kits are good stuff too.
Old Jul 15, 2009 | 01:15 AM
Default thanks
mines the 2wd 3/4 ton, what size tires are u runnin with the 1 1/2 kit
Old Jul 17, 2009 | 03:55 AM
LOGANSTANFORTH's Avatar
all 3500 dodges from 94-02 were duallys, but only the 3500 HD ones were a solid beam axle front with 4x4 style suspension, and those were only available in 94 and 95 model years.......all of the 3500 HD trucks came as a Cab & Chassis setup.....
Old Sep 4, 2009 | 04:29 PM
Rookie's Avatar
hey,
Was told by my dealer that they have used Rough country and Skyjacker and they found that BDS Suspensions are the best kit out there. thought i would pass that on cause i am interested in a leveling kit for my 2010 when i get it.
Old Sep 7, 2009 | 08:50 AM
96cummins1987's Avatar
I got mine from top gun customz for like $80 last year. Its a steel 2" spacer
Old Sep 7, 2009 | 10:05 AM
sidekick's Avatar
good products
