95 6.5 TD about to give heart attack
Old Jul 3, 2009 | 08:46 PM
btsayles's Avatar
Default 95 6.5 TD about to give heart attack
Last week I washed my 95 6.5 TD. After washing, I started the truck, turned it around and parked it in the driveway. THe next day I wanted to put it in the garage while I went up north for the weekend. It would not start. Glow plugs light came on like normal and went out when it was ready to crank and heard the glow plugs click off like normal. Upon turning the key it sounded like the solenoid was firing and then there was a brrrr sound that deminished over a few seconds time frame. I have tried everything from checking fuses to cables. I bridged the starter from the ignition pole to the power pole and got the same sound. I checked the power in both batteries and they are around 12.8 volts as well as checked continuity from each battery lead through to the starter and to the engine as ground. I cleaned the terminals and corrosion at the cable ends. I replaced the starter even though I found later that the origonal was good so I have to rule out that either starter is the culprit. I rotated the engine at the crank pulley so I know that the engine hasn't ceased. I am so gal darn stumped. I can usually figure out things like nothing but I'm about to be completely bald from the head scratching. PLEASE HELP!
Old Jul 10, 2009 | 11:42 PM
wildbill's Avatar
Double check the cable going to the starter. I bet it's corroded enough inside to cause a major voltage loss.
Old Jul 15, 2009 | 08:19 PM
wildbill's Avatar
Or the batteries are bad. Load test them and see what happens.
Old Jul 19, 2009 | 12:12 PM
Big Angry Hillbilly's Avatar
^^ What he said. Voltage drop the cable to the starter from the battery during cranking. You should have no more than .02 volts across the cable.
Old Jul 23, 2009 | 05:30 PM
wildbill's Avatar
Any updates??
Sep 10, 2015 04:30 PM
JamesL91
Mar 15, 2015 06:11 PM
Levis95
Jan 11, 2015 01:54 AM
bdemutis
Nov 28, 2014 08:16 PM
Oct 18, 2014 10:52 AM
