DPF Delete?
Old Jun 24, 2009 | 04:41 PM
dirtymax88's Avatar
Default DPF Delete?
can anybody explain to me what exactly a dpf delete does? and what are the pro's and con's of it? thanks
Old Jun 24, 2009 | 05:39 PM
FarmDiesel's Avatar
+Milage +Airflow +Sound -Warranty -DPF related problems -Your friendship with the EPA
Old Jun 24, 2009 | 06:55 PM
young gun's Avatar
yeah it does that^. but a DPF works by just catching soot and leftover fuel but it restricts air flow and raises yur egt's and engine temp cause not as much air is moving through.in the 2009 may issue of dieselpower there is an 6.4L powerstroke with an ATS performace DPF. i cant find anything on their website but i would try calling a dealer and see whats up with it.
Old Jun 24, 2009 | 07:27 PM
REDRIDE13's Avatar
it decreases fuel milage by dumping raw fuel into the dpf. So that it can burn off all the bad stuff! (pollutants) imo they are a waste!
Old Jun 24, 2009 | 08:47 PM
2500HeavyDuty's Avatar
so much fuel that on the duramaxes it wont go into regen if the truck has a 1/4 tank or less
Old Jun 24, 2009 | 09:33 PM
dirtymax88's Avatar
thanks guys. but what are the dpf problems? could you explain? im trying to figure out because i heard it helps with power and mpg's
Old Jun 24, 2009 | 10:22 PM
12valveNick's Avatar
A DPF works in conjunction with the oxidation catalyst and EGR valve to remove a majority of the NOx, particulate matter (think black soot), and unburned hydrocarbons. Soot is a natural byproduct from the combustion of diesel fuel. Inside the DPF is some kind of honeycomb structure that catches the soot as it goes through. After the soot builds up over time, the onboard computer controls fuel injection to allow unburned fuel to enter the filter at measured intervals where it flares off and generates increased temperatures that burn up the accumulated soot. All it is really does is eliminate emmisions for the enviorment and bog down the engine if you do remove it i think your bound to see improvemnts in power and mileage, might be illegal in california or something though. Hoped i helped good luck
Old Jun 25, 2009 | 02:36 PM
dirtymax88's Avatar
well i live in logan ohio but thanks nick. do you have a dpf delete yourself?
Old Jul 1, 2009 | 12:57 PM
young gun's Avatar
but try askin on the forums for your year the guys will be more knowlegeable and be able to help you more maybe.
Old Sep 27, 2009 | 11:46 PM
I deleted the dpf on my 08 powersroke it was cramping my style
