Fuel Plate
Old Jun 19, 2009 | 06:14 PM
young gun's Avatar
Default Fuel Plate
i kepp hearing guys saying they cut their own fuel plate. is that hard to do and what do you have to do eactly
Old Jun 19, 2009 | 07:51 PM
Coco2992's Avatar
not hard at all, just need to really pull it out and grind on it however you wish
Old Jun 20, 2009 | 01:57 AM
rkadcock's Avatar
N.M. Bombers Director
<a href="http://s24.photobucket.com/albums/c22/snkshit/?action=view&current=plateprofiles0ny.jpg" target="_blank"><img src="http://i24.photobucket.com/albums/c22/snkshit/plateprofiles0ny.jpg" border="0" alt="Photobucket"></a>
this should give you a good idea of how we modify our plates. Its really simple, and when you do grind it, it doesn't have to by 100% exact. But before you mess with your plate, you should look into getting some gauges, especially a pyrometer.
Old Jun 20, 2009 | 12:45 PM
young gun's Avatar
if i grnd the plate to 100 and only slide it half way should i still have guages?
Old Jun 20, 2009 | 12:59 PM
Coco2992's Avatar
GET GAUGES! unless you wanna leave it stock, it will save you alot of money in the long run
Old Jun 20, 2009 | 01:18 PM
BigDiesel359's Avatar
Gauges are a good idea no matter what. If nothing else they can help diagnose any problems as well as monitoring your investment.
Old Jun 20, 2009 | 08:48 PM
young gun's Avatar
if i grind it and leave it in tis stock postion will it be okay? i dont have enough for guages so thoase will have to wait but i dont want to wait on powering it up!
Old Jun 20, 2009 | 09:16 PM
Youre still adding more fuel than stock - I wouldnt touch it unless I had a pyrometer installed.
Old Jun 20, 2009 | 10:51 PM
relay93's Avatar
Listen to what they are telling you about the gauges. I installed gauges 6 months before I installed my first plate and that was 8 years ago. Spend your money wisely and get at least the EGT gauge and for a few dollars more a boost gauge minimum of 60 psi.
You say you don't have he money now for gauges but if you grind the plate and start enjoying the extra H.P. with out monitoring exhaust temps then you definitely don't have the money for a possible rebuild.
Get the Gauges!!!
Old Jun 20, 2009 | 10:54 PM
94cummins12v's Avatar
Get the Gauges!!!
dont bother on gettings a boost guage over 60 garantee you wont use it unless you plan on dumping 10k into performance if you plan on staying stock turbo or mild upgrade do a 35 if you wwant a bit more just get the 60psi, as far as egt most come in a 1400 or 1600 i went with the 1600 becasue i tow alot
