MAP And IAT Sensor Question
Old Jun 16, 2007 | 07:45 PM
Uncle Bubba's Avatar
Default MAP And IAT Sensor Question
Ok now that I have my truck apart, I was cleaning the two sensors. and I have issues here. To start with both sensors took took the same size socket to remove, a 1 1/16th, Iknow that's not supposed to be right. Both sensors also look identical to each other except the shape of the wire plugs. I don't have a white tip sticking out of the inside of either of them. I also thought the IAT only had 2 wire leads but both of these have 3, just in different shape. HELP, what am I lookin at here folks. These are both still factory, I've never changed either of them.
Old Jun 16, 2007 | 08:24 PM
Disregard, to much heat gettin to me. Been in the 90's for the last few day's while we been puttin up hay. Guess I should have waited till I was recovered a little before I went to work on the truck. I found the IAT, I just found a third sensor to go along with these. I pulled one that is down low on the block under the MAP, don't know what it's for, but I cleaned it to. I'll leave my stupidity up here in case somebody else does the same thing.
